  • Guests: 42
GimpyJoe (36)
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
High Voltage Capacitors, inverter grade please. (trades only, unfortunately.)
Inducktion
Fri May 13 2011, 10:11PM Print
I'm looking for inverter grade capacitors (big blue ones)
Just 2-3 of them, their voltage needs to be above 300 volts, preferably 400 volts.
Capacitance can be anywhere from 2000 uF to 3000 uF.
I've got a load of mosfets and semiconductors for trading. I'd like to keep it in the USA if possible.
Thanks!
Inducktion
Sun May 15 2011, 09:05PM
No one has any capacitors they'd like to trade?
magnet18
Mon May 16 2011, 02:10AM
I don't, unfortunately, but have you though about putting some lower voltage in series, or smaller ones in parallel, and been ripping apart CRT's like mad?
(I'm guessing yes, but it can't hurt)
Inducktion
Mon May 16 2011, 02:52AM
magnet18 wrote ...
I have a small cap bank, but the problem is that they're relatively small, and they wouldn't be able to handle ripple currents very well....
The largest ones I have are 2 1500 uF 250 volt ones, but they're pretty old. I measured them with a bridge and they're actually around 1300 uF. So, I don't think I'd trust them with 15-20 amps of current.
