  • Guests: 67
Plasma Speaker Questions
Chip Fixes
Fri May 13 2011, 12:18AM Print
I have two fets wired in parallel, driven with a 555 timer. When I first start it up, the arc is around 2 inches long but after a few seconds its shrinks down to about a cm and stays there, why?
Also, I have had the problem in the past where the arc is long when I play music from my BlackBerry but once I plug in my computer the arc shrinks and I get a lot of high screeching noise.
Thanks in advance for any help!
Fri May 13 2011, 12:27AM
do you have an oscilloscope?
Chip Fixes
Fri May 13 2011, 12:33AM
my physics teacher has one, im scoping the drain tomorrow
Inducktion
Fri May 13 2011, 12:34AM
A number of things could be happening....Do the mosfets get hot at all? Are you running it from a battery? What might be happening is your fets are overheating and thus conduct less current, so less arc length for you. Or, the power supply could be dropping depending on how heavy your load is. And, blackberries and small mp3 players have a bit of electrical noise; stuff that makes the arc all noisy, but the same problem might be happening worse with your computer, depending on its age.
Chip Fixes
Fri May 13 2011, 12:55AM
I have the fets well sinked so they don't heat up at all, currently I'm running it off of a 19.5v laptop power supply, although I have run it off a computer psu and nothing's changed. Tomorrow I will try running it off of just one fet, maybe the 555 isn't switching fast enough?
Fri May 13 2011, 01:18AM
SMPS power supplies can have some deceptive properties. I had a ATX power supply that would fold back from 12V to 7.7 v when i pulled 2 amps, out of a 10 amp channel!
Try a good battery and watch the current input and the voltage across the battery while your running your device. this should confirm or deny quickly the input power issues, after which we can move on to more complicated issues.
magnet18
Fri May 13 2011, 02:09AM
What kind of supply are you using? They like to sag under plasma speaker type loads, especially tiny laptop supplies.
Chip Fixes
Fri May 13 2011, 02:20AM
The circuit is powered with a DELL computer power supply, the flyback is powered with a laptop power supply. I packed up the speaker to bring to school tomorrow, when I get home I will try the battery with the multimeter and I will post the images of the scope.
magnet18
Fri May 13 2011, 02:29AM
Do you have a common ground?
Chip Fixes
Sat May 14 2011, 02:52AM
Ok I scoped it is a weird oscilloscope though and I was unfamiliar with it so I am unsure if I did it correctly... The first picture is of the actual scope, the second is when there was an arc, and the third is when the arc was on but I didn’t ‘engage’ the arc. It's a "bk precision oscilloscope 1403A" I had the "vert input" connected to the drain. The "sweep range (Hz)" was at 1k - 10k and "V. ATT" was at 1/10
1305341214 3781 FT115402 Kgrhqvhce1ipf9frrbndznjdgzq 3
1305341214 3781 FT115402 Graph
1305341214 3781 FT115402 Graph Two
