  • Guests: 69
Inside The CM600 Brick
dude_500
Tue May 10 2011, 02:03AM Print
dude_500 Registered Member #2288 Joined: Wed Aug 12 2009, 10:42PM
I've never seen a picture posted online, so I figure people might be curious what's inside the CM600, and to save you the work of doing this as it's not exactly a fun task opening it to this point (never, ever bandsaw a brick, unless you want a sticky 2 day clean up mess of goo... fortunately someone in the shop warned me of this as I was turning on the saw so I used a hole-saw on the mill instead). This one is a CM600HA-24H
1304993011 2288 FT0 Img 1953
Tue May 10 2011, 02:18AM
Here are a couple pictures of a halfbridge IGBT module i have. It has a lot of different junctions, i have also taken apart a cm400 600v halfbridge brick which had few junctions like the picture you posted.
1304993915 1225 FT115250 Igbt Brick Internals 001
1304993915 1225 FT115250 Igbt Brick Internals 002
That small red square was where i cut a the copper terminal to make it two seperate IGBTs.
Tue May 10 2011, 02:19AM
nice pic, but what are the wiskers for, those cant be the gate connections, right?
Tue May 10 2011, 02:22AM
Patrick wrote ...
Those are actually aluminum wires that connect all of the dies to the terminals including the gate. They are spot welded it seems.
dmg
Tue May 10 2011, 02:30AM
The only brick I ever bothered to look into was a dead SCR halfbridge.
I couldn't find any spot welded wires/bond wires, (either I missed and ripped them out when I took it apart, or it was destroyed in the failiure of the device) but there where mostly just tabs and bridges of sorts bonded to the die to form a half bridge..
And offcoarse, no shortage of the goo.
1304994644 2628 FT115250 Module
James
Tue May 10 2011, 03:31AM
I had something fall on a Fujitsu IGBT 6 pack and crack the cover, so I took it off to repair it. Snapped a pic while I had it apart.
1304998295 3610 FT115250 Igbt
MRacerxdl
Fri May 27 2011, 04:46AM
What beautiful modules!
The ISOTOP (SOT227) cant be opened right? I have two dead ISOTOP mosfets here.
Dr. ISOTOP
Fri May 27 2011, 07:25AM
I think minibricks just have an ordinary die in them...I'm not sure whether you can open them by bending the tabs back and poking them real hard.
