  • Guests: 30
isolation from mains
LD LANGER19
Mon May 09 2011, 12:10AM Print
LD LANGER19 Registered Member #3825 Joined: Sun Apr 10 2011, 08:50PM
Hello, I am going to be using a DC resonant tesla coil soon and I am just making sure that I will not be frying any electronics that share the same circuit / bus in the system. I am using power at my work and I do not want to have any of the computers and even more importantly the server, fail. As the power is sent through 2 MOTs then rectified, I am assuming it is impossible for any high frequency currents to find their way back into the mains?
Thanks,
Daniel
magnet18
Mon May 09 2011, 12:38AM
If you use a big iron cored isolation transformer my guess would be that even if some HF did make it back to that, it wouldn't be able to make it's way past the iron core (thats why ferrites are used for HF).
Even if it did, unless it had substantial voltage, I doubt it would hurt anything, unless you happen to be resonating right at the exact frequency of something else. There are systems out there that actually allow computers to communicate by adding HF noise to the mains line, so you'll probably be OK.
Of course, this is all assuming you get any HF back that far. I've never built one, so I really can't say. Just the two cents of the high schooler.
Mon May 09 2011, 08:21AM
The bad interference usually comes from the magnetic/electric field itself, the MOTs are already isolation transformers and the leakage inductance is so high that any HF interference has no chance of passing through.
Your problem might be the inrush or operating current, which could trip the breaker. When this happens, the huge inductive load (as MOTs are) can induce a pretty bad voltage spike on the circuit which is being disconnected. So you should preferrably run your coil on a circuit where there are no overvoltage-sensitive electronics (mainly switching supplies), if you have no other option, at least put some beefy MOVs on the primaries.
