  • Guests: 23
Madgyver (40)
mike0t4ever (43)
Ken M. (40)
tesla500 (39)
Fabi (32)
hatto018 (40)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
MacGyver Vacuum feedthrough
first  2 3 4 5
Sun May 08 2011, 08:28PM
Ash Small wrote ...
A disc of porcelain may prove to be more suitable, depending on the application.
This is what im thinking.
1304886498 2431 FT115056 Feed Through
The obround is the outside perimeter of the porcelain, 3/8" thick. The inside rectangle with round corners is the hole through the pressure vessel. There are four 10-24 all-thread studs, three 1/4-20, and they all have those Faston ring terminals. it would be attatched to the pressure vessel via PMMA epoxy.
Sun May 08 2011, 08:41PM
Patrick wrote ...
Ash Small wrote ...
Are you going to share the rest of the details about this project with us? smile
Sun May 08 2011, 08:43PM
Ash Small wrote ...
Patrick wrote ...
Ash Small wrote ...
Just a random idea.
James
Sun May 08 2011, 09:06PM
Conundrum wrote ...
Handy for homemade fusors, etc.
Can someone PLEASE tell me where I can fund a decent vacuum pump for less than £50 which works well enough for basic demonstration of poissors etc (1000 Torr or so?)
Thanks..
-A
I got my Welch Duo-Seal pump for a dollar on ebay several years back. Of course it was another $50 to ship (HEAVY!!) and looked like it had spent a year on the bottom of the ocean. It cleaned up real nice after scrubbing inside and out, $40 worth of new seals and fresh oil and eventually got down to 2 microns.
1304888736 3610 FT115056 Pump1
1304888736 3610 FT115056 Img 3458
Sun May 08 2011, 09:39PM
James wrote ...
Conundrum wrote ...
Thanks..
-A
Ive used this exact same pump at shasta college, worked real well when all the old parts were replaced.
Xray
Mon May 09 2011, 12:01AM
James wrote ...
Looks like you did a great job cleaning it up and repainting it. I own 2 Welch Duo-Seal pumps (model 1397) that I use for my X-ray tubehead repair business. They too would suck down to 2 or 3 microns if the pumps were not connected to any other vacuum components. But when connected to my large bell jars with all the associated plumbing, I'm lucky to pull less than 20 microns (on a good day!).
Grenadier -- Excellent idea for mini vacuum feedthroughs! I'm guessing they would be good to about 2KV or so, but you might be able to use them with much higher voltage if you glob lots of silicone or non-conductive Epoxy cement around the conductors.
magnet18
Mon May 09 2011, 12:29AM
So how good of a vacuum can a fridge compressor make?
Xray
Mon May 09 2011, 02:49AM
magnet18 wrote ...
A fridge compressor is not a very good vacuum pump. At best you can get some suction that might be good enough for drying insulating oil (over a LONG time period) but is otherwise not much good for anything else. The problem with a fridge compressor is they are piston pumps, and piston pumps have "head space", which severely limits their ability to pull a vacuum. Head space is the volume of air that remains within the cylinder when the piston is at top-dead-center. Most serious vacuum pumps use rotating carbon or phenolic vanes for producing a vacuum, and serious vacuum pumps used for low pressures are two-stage pumps (like the Welch Duo-Seal series of pumps).
Here Link2 is a very good techinical reference about basic vacuum technology and equipment. There are other good tutorials on the web about vacuum technology, and you just have to search for them.
haxor5354
Mon May 09 2011, 03:11AM
what are you trying to make here? a light bulb? a vacuum tube? an arc lamp? a gas discharge tube?
Adam Munich
Mon May 09 2011, 03:12AM
It's mainly proof of concept, I wanted to make a lightbulb.
Need a pump first though...
first  2 3 4 5
