  • Guests: 26
seveerz (69)
10/18 seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
MacGyver Vacuum feedthrough
Nah
Sun May 08 2011, 01:22AM
You really like pickles Adam
So, I feel a bit thick, could someone explain this?
James
Sun May 08 2011, 04:18AM
He's used the bottom portion of a TO3 transistor with the glass insulated leads to pass electrical connections through the lid into a vessel that can be evacuated. It's deceptively difficult to do normally and proper passthroughs are expensive.
Sun May 08 2011, 04:46AM
I wonder if I could make these out of all-thread screw rod and Porcelain, maybe sell the spares here on the forum?
Sun May 08 2011, 10:37AM
Nah wrote ...
Basically, he has re-invented the Edison light bulb, but it also has plenty of other uses., eg electrostatic grids, vacuum tubes (valves) etc.
Patrick wrote ...
Usually the simplest way to do this is to use an automotive spark plug, inverted, so the long end is inside the chamber. You should also use an unsuppressed plug, eg a Ford Model T plug.
(I'm actually working on what you suggest. I've some 'cement' specifically for this purpose.)
Sun May 08 2011, 02:33PM
Handy for homemade fusors, etc.
Can someone PLEASE tell me where I can fund a decent vacuum pump for less than £50 which works well enough for basic demonstration of poissors etc (1 Torr or so?)
Thanks..
-A
Sun May 08 2011, 03:10PM
Conundrum wrote ...
Can someone PLEASE tell me where I can fund a decent vacuum pump for less than £50 which works well enough for basic demonstration of poissors etc (1000 Torr or so?)
Thanks..
-A
I've a couple of Edwards units, I may be persuaded to part with one, but it is belt drive and doesn't have a motor.
Sun May 08 2011, 05:57PM
Ash Small wrote ...
Patrick wrote ...
Yes but the light bulb and sparkplug are large diameter and long... if i need an array of terminals, then i could use all-thread and a pin-grid arrangement on a rectangular piece of porcelain. Both the porcelain and all-thread Would be custom demensioned easily.
Bored Chemist
Sun May 08 2011, 06:30PM
Conundrum wrote ...
Thanks..
-A
You might want to check your units there. 1000 torr is a little over normal atmospheric pressure.
Sun May 08 2011, 06:54PM
Patrick wrote ...
Ash Small wrote ...
Patrick wrote ...
A disc of porcelain may prove to be more suitable, depending on the application.
(EDIT: I'll post details of the 'cement' I have after I dig it out of the garage.)
magnet18
Sun May 08 2011, 08:14PM
1000 torr is about 1.5 atm, 760 torr is 1atm.
if you mean 100 torr, I have a venturi effect pump I got for like $15-20 that will go that low, it boils lukewarm water at room temperature when I put about 100PSI through it.
