  • Guests: 37
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
Check out my new PSU! (fixed variac)
magnet18
Thu May 05 2011, 10:52AM
Yep, checked again and it's definitely wired fullbridge, any special rules for replacing it or will any high current, low voltage diode do? (it's the 0-12 volt output part)
James
Thu May 05 2011, 04:47PM
Selenium rectifiers have a significantly higher forward drop than silicon diodes but in this application it probably won't make much difference. Whatever bridge rectifier of sufficient current you happen to have will work, either separate diodes or a packaged bridge.
magnet18
Thu May 05 2011, 07:40PM
Righty, I got 2 more, so I'm off to go rip up some tv's and find some diodes...
James
Thu May 05 2011, 08:34PM
The TV ought to have a bridge rectifier on the input in the power supply. You can pull that and stick it right in.
magnet18
Fri May 06 2011, 01:03AM
Right, made a quick schematic, not the best but it's accurate (I think)
1304643644 3766 FT1630 Scan0001
the 2000uF is now 2 1000uF in parallel.
And the TV didn't have a rectifier unit, it used diodes soldered to the board... meh, I'll manage
James
Fri May 06 2011, 02:44AM
Weird, separate diodes will work just fine, but I'm really surprised there wasn't a bridge in the power supply of the TV. Did it use individual diodes too?
magnet18
Fri May 06 2011, 03:12AM
James wrote ...
Haha, found one, but it's not directly attached to mains, it comes after some random transformer and apparently it gets 250VAC in, 24VDC out... from what I can gather from the label...
That doesn't make much sense to me, so I'll play with it.
What do you mean by "Did it use individual diodes too?"
tarakan2
Fri May 06 2011, 03:32AM
tarakan2 Registered Member #3859 Joined: Sun May 01 2011, 03:47PM
Maybe one of the bridge diodes is blown?
Maybe the issue is the variac as it has a contact that picks up current from a specific part of the coil.
Nah
Fri May 06 2011, 09:09PM
I would recomend using a couple hundered ohm reisitor in series with the output of the bridge.
James
Fri May 06 2011, 09:13PM
Not necessary in this design, it's a simple unregulated power supply based on a variac. You'll get a bit more voltage out of it with the silicon rectifier but that's likely to be an advantage rather than a problem. A resistor will just make the output sag more under load.
