  • Guests: 39
davovinch (75)
Duncan (37)
Vatorius (60)
waicool20 (27)
12/11 Forty (38)
12/13 williamn (48)
12/13 ReddyK (57)
Homemade X-ray machine question
first  3 4 5 6
Wed May 04 2011, 01:17PM
The developer does have a 'shelf life'. usually around a year if unopened and refrigerated.
Older developer will not give sharp results.
I seem to remember you used to be able to get powdered developer which had a longer shelf life. (I think Kodak did one)
Wed May 04 2011, 01:19PM
James wrote ...
Get some lead sheet, 1mm thick should be plenty adequate for 50 kVp x-rays.
If we take operating conditions Va 50 kV, Ia 4 mA, filter Al 1mm, the dose rate at a distance of 50 cm will be 5 - 6 Gy/hr depending on beam geometry etc.
The addition of Pb shielding 1 mm will reduce the dose rate at 50 cm to roughly 50 mGy/hr - an unaccceptably high figure.
Wolfram
Wed May 04 2011, 01:27PM
I don't think the MacGyver method will work very well. X-ray developer and fixer should work just fine for developing photographic paper, as both x-ray film and photographic paper are based on the same chemistry.
Edit: I did some googling, and it turns out developing with orange juice is actually possible, and coffe supposedly works even better. It's doesn't work nearly as well as proper developer, of course, but it's actually possible.
Photographic paper is going to have a very low ISO, so it's not practical for direct exposures with a dental x-ray machine (or with a 2X2), you need an intensifying screen unless you want an exposure time of many hours. Ideally you would want blue-emitting x-ray screens, as I don't think photographic paper is sensitized to green light.
Proud Mary wrote ...
James wrote ...
Where are these figures from? They sound unrealistically high.
Wed May 04 2011, 01:53PM
Anders M. wrote ...
James wrote ...
I used RadPro, Anders and then verified its estimate against other sources. As you know, estimates of this kind are never going to be especially accurate, and are designed to err on the side of caution, but they serve very well to give an idea of the order of hazards involved.
Wolfram
Wed May 04 2011, 02:03PM
Anders M. wrote ...
James wrote ...
Your numbers suggest that the radiation from an x-ray tube operating at 50kV is attenuated two orders of magnitude by 1mm of lead, but this Link2 graph that you posted earlier states that even half a millimeter of lead will attenuate the x-rays by five orders of magnitude.
Wed May 04 2011, 02:43PM
Anders M. wrote ...
I don't see any contradiction here. The figures in the graph are derived from probablistic energy-dependent half-values without reference to fluence, whilst the figures I have proposed are for dose rates in Gy/hr 50 cm from the anode at beam cone centre.
Wolfram
Wed May 04 2011, 03:18PM
What is the practical difference between those two figures, why is there such a large difference between them, and why are the numbers from RadPro more applicable? I'm just trying to learn more about this, and this seems a bit counterintuitive to me.
hsieh
Wed May 04 2011, 03:42PM
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I test MacGyver's method.But I use some overdue vitamin pills and ammonia.It works but ofcourse very low quality.(not with X-ray,With ordinary negative film)
This is the very first time I develop photo.
But my dad was VERY VERY angry about the smell of ammonia.
Can I use baking soda or Na2Co3?
So photographic paper cannot detect X-ray?
Wed May 04 2011, 03:54PM
Anders M. wrote ...
Here is a paper by Ray McGinnis, designer of RadPro, on some of the assumptions he used in the calculator design:
Shielding Equations and Buildup Factors Explained
Wolfram
Wed May 04 2011, 03:56PM
Yes, I've seen reports of people using NaCO3 together with orange juice, so this should work fine. Here Link2 is some more info about developing film with coffee.
Photographic paper is sensitive to x-rays, but it's less sensitive to x-rays (and light) than film, because paper usually has a much lower ISO rating (5-25 according to some forum posts I found) than film (100-3000 usually).
Anders M. wrote ...
I would think that the numbers from the NIST graph would me more applicable in this case, as these are the guidlines used for x-ray shielding in practice. The numbers from RadPro are based on theoretical calculations with a lot of unrealistic assumptions. To quote from the RadPro website: "It should always overestimate the amount of shielding required because e-max for the tube head is used when in reality the device produces an entire energy spectrum from lower energies up to e-max.". I think overestimate is a mild word in this case, as assuming all of the energy is at e-max is quite a bold assumption.
first  3 4 5 6
