  • Guests: 59
01/23 GimpyJoe (36)
01/24 OnFire (64)
01/25 Evgenij (60)
Nuvistors and Tek scope bits
Sun May 01 2011, 06:33PM Print
Hi all.
I found a bag of 7586 nuvistors in amongst the other goodies.
Any use? apparently Link2 says they are a "medium mu triode".
Very small VTTC would be amusing although I doubt much power could be obtained.
-A
Nah
Mon May 02 2011, 07:41PM
Nah Registered Member #3567 Joined: Mon Jan 03 2011, 10:49PM
Ah, the nuvistor. The last generation of tubes. These were used in high frez, low powered circuits. These can fech around $15 on ebay, if you're lucky. VTTC? These things process less than a watt!
Could you list the model of the scope and what parts?
Mon May 02 2011, 11:10PM
Yes, how would we know if we are interested in your "scope bits" if we don't know what they are wink
Tue May 03 2011, 10:12AM
Andre, have you got any sockets for the nuvistors? I wouldn't mind trying them for my guitar amp experiments, but the pins are so small, they're feckin impossible to use without sockets. :(
Tue May 03 2011, 04:28PM
I have one... not even sure if its for a nuvistor.
I can check the other boxes though.
BTW a possible fix is to improvise a socket using Polymorph, some turned pin IC sockets with soldered wires, a spare Nuvistor and s heat gun..
Did this once to make some custom phone hack, worked fine.
-A
James
Tue May 03 2011, 05:40PM
Weren't they often soldered directly to the PCB? Most small nixies and VFDs were.
If nothing else, you could build a radio. Simple as it is, it's still a lot of fun to pick up signals on something you put together from scratch.
Nah
Tue May 03 2011, 07:15PM
Nuvistor sockets go for big bucks on Ebay.
Wed May 04 2011, 02:17PM
Hmm. will have a look in the bag o'bits to see whats in there.
Are they any good if a little corroded but still intact?
Arcstarter. I will take some pictures when I have time...
regards, -A
James
Wed May 04 2011, 06:29PM
As long as the seal hasn't failed, a bit of corrosion ought to be fine.
Nah
Wed May 04 2011, 07:41PM
A fourm member might offer to test them on a tube tester, for now, you could check filliments using a Multimeter and the datasheet. I have a friend that might be able to check them
