  • Guests: 65
Neon sign transformer care
Xray
Fri Apr 29 2011, 06:25PM
James wrote ...
I recall the old Sola voltage regulating transformers used saturation to regulate the line voltage. They used to be common for computer equipment although you don't see them much anymore. I remember they ran hot and often were a bit noisy.
I had an older Sola power conditioning transformer a few years ago to regulate the voltage while testing X-ray equipment. It was so noisy that I always had to disconnect power to it when I wasn't using it. Anyhow, to my knowledge, they do not use saturation to regulate voltage but rather they are ferroresonant, as described on the Sola website: Link2
James
Fri Apr 29 2011, 07:01PM
Ferroresonance involves saturation, although there is more to it.
Xray
Fri Apr 29 2011, 07:48PM
James wrote ...
Interesting! Thanks for the link.
Nah
Sat Apr 30 2011, 05:40PM
I use one of those on the bench. It weighs around 40 pounds and only goes up to 6.5 amps.
