  • Guests: 44
Mini SSTC
James
Sat Apr 23 2011, 07:59AM Print
I wound a secondary specifically for my version of Steve Ward's SSTC5. Gotta say I'm very pleased with the performance of this thing. I still need to cap off the secondary form and add a proper discharge terminal but overall I'd say this works very well. I get sparks very similar to those of the VTTC although drawing around 450W this is significantly more powerful. I think I'll change the heatsink to something more compact since it doesn't even get warm, it could run all day long.
1303545567 3610 FT0 Suc53434
Matt Edwards
Sat Apr 23 2011, 03:19PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
Nice! Now it's time to build a bigger one ;)
magnet18
Sat Apr 23 2011, 06:15PM
Very nice!
Whats the primary voltage?
James
Sat Apr 23 2011, 09:10PM
I'm using this circuit Link2 Primary is filtered 170VDC feeding a half bridge.
I like these compact coils, fun to play with but cheap to build and don't take up a huge amount of space.
magnet18
Sun Apr 24 2011, 12:14AM
you mean 120V?
I might build one of these, looks like a quick project,
Do you think you could wind a larger primary and power it off a flyback? because I can do that in like an afternoon...
James
Sun Apr 24 2011, 12:32AM
When you rectify and filter 120VAC you get 170VDC. 120V is the RMS of a sine with a peak to peak value of 170.
You can't power it off a flyback, completely different principal here. It's a semi resonant design that picks up the RFI with a little antenna wire and uses that feedback to drive the primary at the resonant frequency of the secondary. The mosfets directly switch the primary voltage and there's quite a bit of current involved.
magnet18
Sun Apr 24 2011, 12:42AM
But it doesn't spend all of it's time at peak voltage...
anyway, that makes sense, thanks
ZakWolf
Sun Apr 24 2011, 02:01AM
awesome coil, I cant wait till I get mine up and running, what are your secondary specs.? If you dont mind.
James
Sun Apr 24 2011, 06:38PM
magnet18 wrote ...
The capacitor charges to the peak voltage and maintains it between cycles. Trust me, you get 170VDC when you full wave rectify and filter 120VAC.
magnet18
Sun Apr 24 2011, 06:46PM
Okey Dokey
Could an isolation transformer be used before rectification, or would that limit the power too much?
(HV hobbyist fears death by 120/170V :P)
