  • Guests: 65
120kv 10-20mA SMPS
Adam Munich
Tue Aug 23 2011, 02:36AM
Maybe you could go the DC flyback route and half wave rectify it? That would reduce the capacitive + inductive losses, and make insulation a lot easier...
Linas
Tue Aug 23 2011, 07:10AM
jpsmith123 wrote ...
I think it will be very difficult if not impossible to get 65 kv (peak) out of a "typical" ferrite transformer. You will run into problems with parasitic capacitance and/or capacitive coupling to the core, and insulation problems.
I think you'll probably have to go with a significantly lower transformer voltage and a correspondingly bigger multiplier.
thanks for simulation. you get same results as i with miltisim.
I have ferrite core from original high power 140kv CT
1303541934 1143 FT113887 P1590589
now just question, should i wind turns like in photo, or should i use 2 U in parallel, so window will be 6x6cm (not 12x6cm as in photo) but that will double core area to 11cm^2 and will reduce turns by two in secondary as in primary.
right not thinking about 6.5k turns in 12x6cm core, or 3.25K turns for doubled core
and how to calculate voltage degradation caused by parasites ?
jpsmith123
Tue Aug 23 2011, 03:39PM
Wow I've never seen a ferrite core like that before!
I wonder, how was it used in its previous life, i.e., what was the secondary voltage, drive frequency and winding geometry, do you know?
I think if it was me, my first inclination would be to try to run the secondary at no more than 30 to 35 kv and then quadruple it.
What's the core cross sectional area? Can you get 30 volts(peak)/turn at 25 or 30 kHz without heating up the core too much?
If so you'd need somewhere around 1000 to 1200 turns of 30 gauge (or maybe 28 gauge) wire.
Adam Munich
Tue Aug 23 2011, 03:46PM
I still think a CW is the way to go. Make it a 4 stage center tapped one, so you get the voltage increase of 4 stages with the problems of only 2.
That core looks much like the one I used for my fryback, and I was only able to get a maximum of 30kV out of it before the core saturated. Link2
Linas
Tue Aug 23 2011, 04:13PM
wow, nice flyback
But my core is at least 2x bigger and has 2-3x cross section.
its 28x20mm ( at least what i am seeing from photo, tomorrow i will have it near me, so i will do measure it)
This core was used in 100KW CT machine, and biggest part of power was used by tube, and tube was powered by flyback.
Flyback was huge, with oil impregnated paper as insulator, and had 20 layers. each layer had it's one 17xBYV26E diode string to reduce capacity.
i have 2 from 3 U shape cores, so i should easy get around 20KW output from this core.
i already have transformer for filament, and made driver for it on my SMPS pcb, so i will keap filament power supply as it.
and most important part:
in my CT scanner box i have 19*19x11cm space for voltage step up part, so i don't want again remade all existing parts frown
so 65KV and 2x sounds best for me.
( one more question, if i increase V/turn, i will get less parasites, and therefore more voltage in output, right ?, because if i stack U shapes, i just need around 5-10 (15-30V/turn) turns for half bridge, but if i use it in series i need (12x6 window)10-20T (7,5-15V/turn) )
Fabi
Tue Aug 23 2011, 04:55PM
Fabi Registered Member #3510 Joined: Mon Dec 13 2010, 08:31AM
Hi
Intersting project :)
I'm working parallel on pretty the same project (CT) and I'm designing a SMPS and x-ray sensor
(I need 110 kV at 10-20 mA.) btw.
I think that a CW multiplier is the most-effective solution. (max. 4 stages)
But I have to think once about it... maby there is a better one...
How about a marx-generator? You can trigger it by a trigatron)
The next thing is:
Do you want the tube to produce x-rays continously or do you want to trigger it to the camera?
Anyway: Most likely we have to use a combination of caps and diodes... because it's nearly impossiblt to handle such a voltage with a "stans-alone" transformer with an acceptable budget
I hope, I didn't skip anything...
Dr. ISOTOP
Wed Aug 24 2011, 12:51AM
Fabi wrote ...
This this this.
There is nothing wrong with a CW, especially at these low currents.
All of the world's high-quality HV supplies use a multiplier stack.
Linas
Wed Aug 24 2011, 03:32PM
i finally get cores, but noticed that if i use 2x multiplier, i have no place for caps and diodes.
So i have to make single 120KV transformer, with 15V/turn and use full 4 diode rectifier, that sounds like breakdown for me sad
Fabi
Wed Aug 24 2011, 06:22PM
ok...
I'm gonna do it with a multiplier...
anyhow
Please note that 120kV eff is about 170 kV peak btw...
Linas
Wed Aug 24 2011, 07:05PM
Fabi wrote ...
no, because i have square wave from half bridge ( IR2153 controlled ) (150Vac Half-bridge with 300V supply)
check your pm wink
