  • Guests: 45
100W Sonoluminescent Bubbles
IntraWinding
Thu Apr 21 2011, 10:39PM Print
This sounds easy to do. I wonder if a single flash would be visible if you used a transparent cylinder?
Thu Apr 21 2011, 11:10PM
Here are details of a very basic sonoluminescence setup which works:
Fri Apr 22 2011, 05:42AM
Probably a stupid question, but could it be possible to generate the initial bubble using a pair of pulsed, focussed 2W 445nm lasers?
-A
Daedronus
Fri Apr 22 2011, 11:19PM
I guess 4W is a bit too low, but I'm betting a q-switch nd:yag will have no problem....after all they can ionize plain air.
