  • Guests: 54
seveerz (69)
10/21 ben106 (40)
10/22 803 (2025)
10/23 Iniaes (17)
So I got this Tube...
steve516
Sat Apr 16 2011, 11:20PM Print
steve516 Registered Member #3832 Joined: Thu Apr 14 2011, 11:57PM
Hey all. First, I want to introduce myself- my name is Steve, I'm from Cleveland, OH. I like playing with big tube-powered toys, as well as rail guns, transmittera, tesla coils, really anything that has an awesome amount of power. I work in the film industry, so I don't have any sort of engineering background or anything.
Anyway, I love your forum here and finally decided to join as a member to contribute my fun.
A friend of mine recently dumped off a nearly unused navy surplus Eimac 4-1000a to me. It's the largest glass tube I've ever seen or owned, and I quite frankly can't decide what the he'll to do with it! I had a few ideas:
Excessive VTTC
The largest BCB AM transmitter I've ever built
Induction heater
Any thoughts?
Steve
Xray
Sun Apr 17 2011, 05:24AM
Hi STeve, welcome to 4hv!
The 4-1000 is normally used in the final amplifier stage of a radio transmitter. The number 4 indicates that it's a tetrode (cathode, control grid, screen grid, and plate), and the number 1000 indicates that the plate can dissipate up to 1000 watts of power.
As for those projects you mentioned, I'm sure that you understand that you will need a LOT of other high power components to power that big tube! And don't even think about using it as a BCB transmitter unless you want the FCC kinocking at your door! (but of course you CAN transmit on the broadcast band if you are properly licensed).
The 4-1000 is an awesome tube, but expect to spend a lot of cash on the power supply and the perifpheral components unless you have a well-stocked junk box!
If/when you do build a project with it, please share the details with us here on 4hv!
Xray (real name: Mike)
steve516
Sun Apr 17 2011, 12:59PM
Thanks Mike!
We'll see what I can come up with. Right now Tesla coil is looking like the best choice. I may wind the filament tranny out of an old MOT.
I could just display it, it's a beautiful tube all by itself.
Steve
James
Mon Apr 18 2011, 01:49AM
Seems like the power supply shouldn't be too big of an issue. A lot can be done with a MOT or two, and they can be had for free.
Ought to make a nice VTTC. A tube that size could handle some serious power without pushing it anywhere near the limit. You could run the coil for good lengths of time and still get a lot of life out of the tube.
Xray
Mon Apr 18 2011, 03:52AM
steve516 wrote ...
Thanks Mike!
Steve
I recently built a VTTC with a 6146 tube, which is quite a bit smaller than your 4-1000, but I was pleased that it works fairly well for my intended purpose (a plasma speaker). You should be able to built a very large VTTC with that big tube!
In my opinion, putting a working vacuum tube on display, and not using it, is like displaying a beautiful but functional gun. A gun is meant to shoot, even though some of us wacky gun collectors love to admire the fine craftmanship of a quality handgun. Put that tube to good use!!
By the way, do you have the tube socket for that tube? I recall from my amateur radio days that high power transmitter tubes have expensive sockets which often include a glass cooling shroud, and a fitting for forced-air cooling. A 4-400 tube that I once used in a linear amplifier had that type of socket and glass shroud. The socket cost me more than the tube did back then!!
Mon Apr 18 2011, 03:59AM
If you build a VTTC out of it, make a base fed audio modulated one (plasma tweeter). The base fed design requires few components to handle the reactive power, and a large plasma tweeter is impressive. I built one using a 4-400 which is a bit smaller then your tube. Worked good except it had some modulation issues.
steve516
Mon Apr 18 2011, 04:49PM
Weston wrote ...
That would be awesome... I have no idea how to audio modulate it, but I would love to do that. Maybe you all can help out there! :p
I don't have a socket ATM, but will look for one.
Xray
Mon Apr 18 2011, 05:04PM
steve516 wrote ...
There are plenty of scematic diagrams and construction plans on 4hv and other places on the web for "plasma tweeters" and "plasma speakers". You can also find some information if you search on "singing arc".
FYI -- I audio modulated my 6146 plasma speaker by capacitor coupling my audio signal into the screen grid of the 6146 tube. You can also modulate the tube with an audio transformer in series with the plate B+ supply, and I've even seen a design that fed the audio signal into the cathode of the tube, across the cathode resistor. So, there are many ways to modulate, but it must be done correctly, otherwise your audio will be weak and/or distorted (as are many projects found on YouTube).
If you have limited electronic experience, especially with vacuum tubes and RF circuits, then a project of this sort may be more than you should tackle until you've gotten more education and experience. My biggest cocern here is with electrical safety. The voltages and currents that typically power a large transmitting tube like the 4-1000 are extremely dangerous, and can be fatal if you make only ONE mistake!
Nah
Mon Apr 18 2011, 07:13PM
If you want a VERY loud speaker, you could try inductivly coupled plate modulation in a Class C Armstrong.
steve516
Fri Apr 22 2011, 07:12PM
Nah wrote ...
Would love it, obviously. Cant picture anything better than playing my bass through a thousand watt plasma flame. Primus obviously.
Gonna look into that and post back in the projects forum when I start.
SK
