  • Guests: 32
Resonant freq of secondary
mystique
Thu Apr 07 2011, 08:10PM Print
mystique Registered Member #3816 Joined: Wed Apr 06 2011, 11:49PM
Should my secondary coil have two resonant frequencies? I have 250khz and 900khz
Thu Apr 07 2011, 09:12PM
It's not uncommon for real world LC circuits to have multiple resonances - desired and undesired, both.
ScotchTapeLord
Thu Apr 07 2011, 10:35PM
If it is the same coil as in your other post, 250kHz sounds right.
How did you determine 900kHz?
mystique
Thu Apr 07 2011, 10:45PM
a scope and signal generator, looking for amplitude shift
GeordieBoy
Fri Apr 08 2011, 02:46PM
250kHz sounds like the quarter wave mode, and 900kHz sounds like the three-quarter wave mode. 250kHz is the resonant mode you want to drive it at, unless you can find any more resonant peaks in the region below 250kHz!
Out of interest was it tested with a toroid on the top? ...or just the bare resonator? The addition of a toroid shifts the resonant mode frequencies.
-Richie,
mystique
Fri Apr 08 2011, 03:16PM
with toroid
