  • Guests: 38
02/03 Bauerb2 (36)
02/04 Fabio (46)
02/04 Corey (35)
110V 400Hz variac uses?
Sun Apr 03 2011, 04:12PM Print
Hi all.
Just got this from a clearout, the nice guy who gave it to me seems to think it is working.
Any ideas if it is useful at lower frequencies?
Obviously I will need a 240-110V converter but it would seem handy for testing SMPSs etc.
-A
Sun Apr 03 2011, 05:20PM
It's useful at lower frequencies, with no change in the current rating
and with the voltage derated by the frequency ratio 50/400 or 60/400.
An instructional first step would be to drive the entire winding with another variac. Slowly increase the voltage while charting the magnetizing (no-load input) current.
Xray
Mon Apr 04 2011, 08:30PM
Xray Registered Member #3429 Joined: Sun Nov 21 2010, 02:04AM
I know from experience that a 400Hz transformer will overheat when operated on 60Hz, and I can assume that a Variac would have the same problem. I think you might end up using it as a boat anchor! frown
James
Mon Apr 04 2011, 08:54PM
As Klugesmith says, it will overheat (saturation) at rated input voltage, but if you reduce the voltage accordingly it will work fine. In this case that would work out to about 18V input at 60Hz, or 15V at 50Hz. Might still be useful as a low voltage regulator.
