  • Guests: 27
Dago (37)
Z28Fistergod (39)
JonIverson (45)
Liquidspaceman (67)
12/06 Dago (37)
12/06 Z28Fistergod (39)
12/06 JonIverson (45)
Coil gun tennis ball launcher
EL
Thu Mar 31 2011, 01:47PM Print
EL Registered Member #3799 Joined: Thu Mar 31 2011, 01:34PM
Hello,
We are a team of engineering students from the University of Louvain, working on a coilgunproject. We are trying to build a tennisball-launcher that is able to shoot a ball over a distance between 0 and 9 meter. A picture is included as attachment.
Some features of our design:
* Our solenoid is made out of 0.8 mm coil wire which is turned around an aluminum tube (diameter 36mm). Between the coil wire and the tube is a thin plastic foil.
* The launching tube is placed at an adjustable (positive)angle so gravity will be working against us.
* The movable piston (with projectile) which we're planning to suck into the coil in order to propel the tennis ball has a weight of 0.5 kg.
We still have some important questions unanswered:
* First of all: is this project achievable at all :)? Knowing that we cannot use line power, but we do have a car battery of 12V.
* Is it better to use a plastic tube instead of an aluminum one. Does this influences the magnetic field a lot?
* We already did some calculations, but these are very hypothetical. We don't really know what to expect in terms of force on the movable piston.
* Which current/voltage is required to evoke such a force? Can our battery deliver this?
* Most coilgun designs make use of capacitors, is this necessary since we do not have to propel the piston out of the tube, we only have to accelerate it to a speed large enough to launch the ball.
We would be very grateful if you could help us with these questions.
Thanks in advance.
Greets from Belgium smile!
1301579181 3799 FT0 Movable Piston
1301579181 3799 FT0 Dsc03843
1301579181 3799 FT0 Dsc03828
Killa-X
Thu Mar 31 2011, 02:38PM
Well something I never thought of. My only concerns, I don't know much of coil guns though, is if it will have enough kick to get it going as far as you want it to, instead of a short 20-30ft kick. I can't say.
I think though this is a rather fun idea to try...I would at least give it a try to see what happens regardless of what people think on how far it will shoot. I havnt seen it done, so why not try? I'd actually like to take this concept to a different level sometime. Bb gun that used a coilgun style solenoid to shoot the BB...
teravolt
Thu Mar 31 2011, 07:36PM
a tenis ball is prety light. A coil launcher has lots of force behind it but what you need is velocity. It's a lot like pumpkin-chukin. if you used a inverter and a set of caps you might be better off. is there some level of safty that you have to conform to?
Turkey9
Fri Apr 01 2011, 04:43AM
You need to use a plastic tube to wind your coil on as aluminum will severely deform your field due to eddy current losses.
If you make a really beefy coil (thick wire and few turns, say 10) and the plunger is quite heavy, the car battery might work. The only problem is that with a 12V source like that there will be very very large currents needed in order to get much of a force on the projectile. I'd go inverter charged caps and make it almost like a conventional coilgun.
But definitely change that aluminum tube out.
Killa-X
Fri Apr 01 2011, 01:16PM
Coilgun wise, I will say I'm sure PVC would be fine. I have done wire spools for coiguns, Dont. After X amount of shots, the spool caved in and I had a closed middle.
Do you intend to keep this to a power source driven launcher, or possibly turn it into a capacitor bank coilgun launcher?
