  • Guests: 26
Will T (16)
william L (29)
Tipiment (62)
12/17 Ben7 (29)
12/18 Skywarrior (52)
12/18 Dark Horse (54)
HV supplies from a photocopier
Tesladownunder
Sat Jun 10 2006, 05:26AM Print
I gutted a Toshiba photocopier a few days ago. Lots of other stuff including 2 HV supplies. They have 4 input wires so I was a bit stuck to work out how to get them to go. This is how I did it.
1 Work out the supply voltage from the main power board. Most things seemed to be 24V rated so I went with that.
2 Check the small filter electrolytic cap polarity with the broader PCB tracks that connects near the input wire connector, to determine which is positive and negative. (No positive is not the red wire - thats just in movies where they defuse the bomb)
3 Connect the supply - start with 12V to make sure minimal current drain at this stage.
4 By trial and error touch one of the two remaining wires to earth. Bingo its running. Cut off the other wire. Draw is about 130mA 24V no load.
The larger supply was 5kvDC, 3.8kV AC and a few smaller voltages.
I have added a cap to show it is DC and brighten up the sparks.
Peter
1149917173 10 FT0 Hvsupplyphotocopier5kv
1149917173 10 FT0 Hvsupplyphotocopiersmaller
Sat Jun 10 2006, 08:02AM
yeah these mini flybacks are really nice, I got 20kvdc from one of them with minimal power. (with my own driver of course)
J.M.
Plasmaniac
Sat Jun 10 2006, 09:07AM
Plasmaniac Registered Member #206 Joined: Sat Feb 18 2006, 03:17PM
I've blown one some days ago (I think its primary's dead)... seems like 200-300W are too much tongue
I still have an other one and I'm going to power an other nanoSGTC with it.
Sat Jun 10 2006, 09:19AM
Some years ago I got a -7kV 0.2 mA hv supply from a laser printer
very small and 'cute'
I ran a small SGTC off it for a while
about 50mm arcs from 0.7W.
Lasted a couple of years powering misc. experiments
now it's in the pile waiting for resurection.
Simon Barsinister
Sat Jun 10 2006, 12:16PM
Simon Barsinister Registered Member #116 Joined: Fri Feb 10 2006, 03:19AM
I work on Toshibas.. if you need a pin-out , just tell me what model copier it was.
Rich
