  • Guests: 62
Arjan EMM (52)
01/01 Bosko (56)
01/01 hen918 (30)
01/01 Yuri_Ivanov (35)
Small Tesla coil power supply
1 2 3 4  last
ZakWolf
Tue Mar 29 2011, 06:32AM Print
I was working on a small Tesla coil for awhile until I got around to the power supply, I never got the one I planned and I need to find an alternative. I was thinking about buying two nice big flybacks from eBay or some other internet store and putting them in parallel, I will use a ZVS flyback driver to power them and submerged the flybacks in mineral oil to insulate/ cool them. I use “Tesla coil CAD version 2.0” to calculate my coils and I want to know the flyback voltage output and current output in parallel and I have no clue how to do so. So any help would be appreciated.
Also does anyone know of any good FBT supplier?
Coil size:
12 inches tall
2 inches wide
28 gage magnet wire
Approximant turns - 949
Dr. ISOTOP
Tue Mar 29 2011, 06:56AM
You should wind your own ferrite transformer; they stand up to high power better.
A single-layer secondary is not that hard to to, and can (probably) do 10KV if done right. Even 5 or 6 KV is enough for an SGTC.
ZakWolf
Tue Mar 29 2011, 02:27PM
I thought I need to know the output so i calculate the capacitor. What do you mean single layer? If i wind my own i will have to rectify it with a bridge or just a diode?
Dr. ISOTOP
Tue Mar 29 2011, 03:36PM
Full-wave rectification is always good, but half-wave is fine if you are tight on budget.
Check Steve Ward's CCPS page for details on what I'm talking about.
ZakWolf
Tue Mar 29 2011, 03:55PM
I was thinking if i by two good flybacks there gonna cost atleast 20 dollars so should i just by a 50$ oil burnner ?
Edit: Would this work for a powersupply Link2 . It says 20kv peak but at what current?
James
Tue Mar 29 2011, 05:26PM
Oil burner ignition transformers are usually 5-10mA, but that looks like it may be an electronic one, you probably are better off with the old iron transformer type. Is oil heating common in your area? If so you may be able to score a used transformer from a HVAC shop.
As for rectification, half wave is likely to give you problems with core saturation, you're really better off to spend a few bucks more on full wave.
ZakWolf
Tue Mar 29 2011, 10:24PM
ok I will go with full wave rectification. So what about a dual stack flyback supply? I just want decent discharges nothing crazy, the thing is if i go with two fly backs how will i find voltage and current to calculate my tank cap?
James
Tue Mar 29 2011, 11:20PM
If you drive it push-pull the voltage will be pretty close to the turns ratio, so you can drive it at a low voltage, maybe a volt or two and measure the output and extrapolate from there. Flybacks have limited current due to the very small wire in the secondary, maybe 1-2mA. Don't you normally pick a ballpark value for the cap and then tune the primary? The voltage can be adjusted by adjusting the DC input. It's surprisingly easy to wind your own ferrite HV transformer too, at the frequencies involved you can push 20-30V/turn from a modest size core.
Neon and oil burner transformers turn up on ebay from time to time for reasonable prices, and stopping at a sign shop if you can find one will likely net you a few. Flyback is a nice high tech approach but you shouldn't have to spend more than $10-$25 for either solution.
ZakWolf
Tue Mar 29 2011, 11:31PM
A neon sign transformer for 10-25$, really? Don't NST's have to have a terry filter to protect them? Thanks, I will look around for a neon sign shop.
Dr. ISOTOP
Wed Mar 30 2011, 02:28AM
For small tabletop coils, an small (say 7.5/20 or 9/30) NST is probably the best and most robust solution.
If you want cute and tabletop, you can always go solid state - the unloaded fres of your secondary is around 1 Mhz, which is good for switching with MOSFETs.
1 2 3 4  last
