  • Guests: 38
Do I have to varnish PVC pipe before wind secondary?
steven968
Sun Mar 20 2011, 08:45AM Print
steven968 Registered Member #3516 Joined: Wed Dec 15 2010, 10:40AM
I use fine sandpaper make PVC pipe smooth. Is it ready for varnish?
Coronafix
Sun Mar 20 2011, 08:42PM
You can vanish it before winding if you want to.
I found that it is not necessary if it is pvc. If it was cardboard, i definately would
varnish before winding.
Just make sure everything is clean.
Gregory
Mon Mar 21 2011, 01:11AM
Here, when I used PVC I never varnish before but after wind is very recommended
Sparrow338
Mon Mar 21 2011, 01:21AM
Sparrow338 Registered Member #661 Joined: Sat Apr 21 2007, 03:17AM
I usually sand off the outer shiny layer of the PVC, then clean and varnish it.
Honestly varnishing before winding is probably necessary, no performance difference (that I have seen).
However one "bonus" of varnishing first is that it will cause the wire to stick to the coil form if you don't let it dry completely, can save you if you accidentally loose wire tension while winding.
-Sparrow
