  • Guests: 41
01/18 Noelle (43)
01/18 King_of_Junk (36)
01/18 Ixz (35)
zener diode issue
steven968
Thu Mar 17 2011, 09:58AM Print
steven968 Registered Member #3516 Joined: Wed Dec 15 2010, 10:40AM
Hi guys,
If I connect two 8v zeners in series, will it turn into "16v zeners"?
If I parallel two zeners, the power rate will double?
thanks.
Daedronus
Thu Mar 17 2011, 10:52AM
first, yes, second nope
diodes in parallel are a evil thing, avoid it at any cost
ScotchTapeLord
Thu Mar 17 2011, 05:32PM
Zener diodes are some of the few devices you can series reliably. You may not be able to parallel them, but putting them in series will also raise their power handling ability. I.e. Two 8 volt 1/2 watt zeners in series will be a 16 volt 1 watt Zener.
Gregory
Sat Mar 19 2011, 06:29PM
I don't know about man.... If you have two zeners in series the current in each won't be half the total current then you will have total dissipation in each zener
Dzejwor
Sat Mar 19 2011, 07:04PM
Dzejwor Registered Member #2750 Joined: Sun Mar 21 2010, 08:47PM
Yea but you have half of the total voltage on each diode. If you have 1/2W 8V zenner you can put 63mA. If you series two 8V 1/2W zenners you stil can put 63mA but at 16V this give you 1W.
ScotchTapeLord
Sat Mar 19 2011, 07:07PM
Current is not the only component of power.
Power = VI, and with two Zener diodes in series, the voltage is halved for each.
steven968
Sun Mar 20 2011, 08:42AM
thanks guys
