  • Guests: 85
How to tune SSTC primary?
hsieh
Tue Mar 15 2011, 12:55AM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I'm still trying to optimize my miniSSTC.I tried to add or remove some primary turns but no matter what I tried the spark is less than 10cm(110VAC input) and MOSFETs gets very hot in several seconds.
Any webpage explains how to turn SSTC?
My currently secondary is 11cm in diameter ,length is 40cm 1000turns.My primary is 5 turns on the same PVC pipe.I use IRFP250 and I install a big heatsink.
I followed the original steve miniSSTC except disable body diode like this Link2 and using IRFP250 instead of IRFP260.I can't find IRFP260.
Thanks
Matt Edwards
Tue Mar 15 2011, 02:11PM
Matt Edwards Registered Member #2838 Joined: Fri Apr 30 2010, 07:55PM
For the primary you can run all of your numbers here. It will give you a basic idea of what you are working with.
radhoo
Tue Mar 15 2011, 02:45PM
For my HFSSTC, I simply slide the primary coil up and down over the secondary. Easy: Link2
150x150150x150
Gregory
Tue Mar 15 2011, 04:39PM
you can't tune a a sstc, if you do this the coil will be a DRSSTC and will run very bad with sstc circuits (will run ok, but isn't safe)
radhoo
Tue Mar 15 2011, 08:51PM
Gregory wrote ...
Maybe, is this what you mean: Link2 ?
Inducktion
Tue Mar 15 2011, 09:34PM
radhoo wrote ...
Gregory wrote ...
Radhoo, could you possibly PM me the schematic for the Armstrong oscillator you used? I would like to adapt it to other purposes.....*rubs hands together*
radhoo
Tue Mar 15 2011, 10:08PM
Inducktion wrote ...
Sure - You can find the schematics on the page I've posted, but here is the link again: Link2 . The circuit diagram is the first picture at the top.
Inducktion
Tue Mar 15 2011, 10:12PM
radhoo wrote ...
Other purposes being an induction heater ^^ I wonder and hope this will work.
radhoo
Wed Mar 16 2011, 12:19PM
Poor yellow rubber duck, it appears that one way or another - is going to get cooked after all.
Matt Edwards
Wed Mar 16 2011, 05:59PM
Gregory wrote ...
Um.. What?
