  • Guests: 47
Tsunami warning
Ash Small
Fri Mar 11 2011, 03:05PM Print
Seven foot high Tsunami due to hit California in an hour's time. (8am PST, 4pm GMT).
Nicko
Fri Mar 11 2011, 08:04PM
Ash Small wrote ...
That'll be a neat trick - it was only just over 3 ft when it got to Hawaii...
Ash Small
Fri Mar 11 2011, 10:24PM
Nicko wrote ...
Ash Small wrote ...
I'm only passing on what was reported (see link), I heard it was 5 or 6 foot at Hawaii (1.6-1.7 metres).
I saw the damage on TV in the marinas in LA, but I've not yet seen any other reports. Thankfully it doesn't appear it was as bad as was predicted.
Sat Mar 12 2011, 07:58AM
If Japans reactors send radioactive chemistry all the way across the Pacific to California, I will be so pissed. Dam it.
Ash Small
Sat Mar 12 2011, 08:28AM
Latest reports are saying the outer structure of the reactor has 'blown off' and that radioactive caeseum and iodine has been released.
EDIT: "The ceiling of reactor number one has collapsed"
The wind is apparently blowing east, across the Pacific.
9.07am: "Japan chief cabinet secretary Edano: Confirms radiation leak at Fukushima plant"
Sat Mar 12 2011, 08:54AM
notice the difference in reports...
Looks like at least one of the reactors nearly went into meltdown because it took a direct hit from the wave which damaged the cooling system and weakened the buildings, causing the diesel backup generators to fail as well.
Luckily it appears that they managed to contain it so any radioactive leakage should be minimal.
Just what they didn't need at this point with all the relief efforts for the tsunami and earthquake.
-A
Sat Mar 12 2011, 09:23AM
that outer-most building does look like it went "high order" sonic or transonic pressure wave shooting straight up, through the roof of the buidling/containment pressure vessel. Really looks like a steam explosion. Shit...
Hopefully the pressure vessel will remain intact, if it is significantly breeched (as with Chernobyl) California (And thus ME) will be glow in the dark shortly.
