  • Guests: 46
Steve Ward MINI SSTC (SSTC5) problem
gsila
Thu Mar 10 2011, 06:19PM Print
gsila Registered Member #1876 Joined: Sun Dec 21 2008, 08:33PM
Im trying to build Steves coil, but im having some troubles... soo please if can anybody check my PCB for any mistakes.
1299781047 1876 FT0 Dfafa
mmt
Thu Mar 10 2011, 06:45PM
mmt Registered Member #2333 Joined: Thu Sept 03 2009, 03:04PM
where is gdt cap?
gsila
Thu Mar 10 2011, 06:49PM
GDT cap is C6 on half-bridge board
mmt
Thu Mar 10 2011, 06:59PM
oh sorry, i see :D
what capacity has C4,5.
did u put something in cap. and res. subs?
gsila
Thu Mar 10 2011, 07:06PM
C4 and C5 are 100nF
On res.sub i puted a jumper and on cap.sub a capacitor 2.2uF
mmt
Thu Mar 10 2011, 07:17PM
hmm, it seems design is fine, just put zeners on your FETs, what exact troubles you have with this system?
gsila
Thu Mar 10 2011, 07:37PM
i have MUR860 diodes at FETs.
hmm troubles ...Input voltage is 320V(i have IFRP460) and output is just a couple of volts without coil connected. if i connect the coil, voltage drops to zero. Ithink that there is somthing wrong with half-bridge board but i cant find what. For C7 & C8 i have 1uF 630V cap
gsila
Thu Mar 10 2011, 07:50PM
mmt
Sat Mar 12 2011, 09:27AM
for tests use just a couple of volts on bridge 24-48V and then try to tune your coil.
gsila
Sun Mar 13 2011, 08:25PM
YAY its SPARKING now. I had to big mosfet gate resistors
