  • Guests: 81
When a Mazzilli driver just isn't enough...
James
Tue Mar 08 2011, 09:26PM Print
This is essentially the same circuit, but designed to operated straight off the rectified mains at up to 1.8kW. Note that a stock flyback transformer will NOT tolerate anywhere near this much, but you could probably stack several salvaged cores or buy one from John and wind your own HV secondary. The output will of course be extremely dangerous, as if the Mazzilli driver wasn't dangerous enough.
As an induction heater it's pretty cool too :)
Inducktion
Tue Mar 08 2011, 10:03PM
Yeah... The only thing is though is why he added those other parts? Like those 1.5uF caps, or that MUR diode to the circuit? What's their purpose?
James
Tue Mar 08 2011, 10:24PM
If you read the articles, he explains the design process, revisions, and how the circuit works.
