  • Guests: 36
williamn (48)
ReddyK (57)
Birdman (31)
12/14 M.A.D. (32)
12/15 marko666 (58)
12/16 Will T (16)
The toner transfer method.
Wed Mar 09 2011, 10:16AM
As I said, I have too much trouble even finding the same paper over again, and all glossy papers I've used left the coating of gloss on the board.
I like the magazine paper method the most of this, does any of you have pics of the work with it? The only problem I can think of it is that being colored it might be difficult to adjust for double sided boards.
Wed Mar 09 2011, 03:38PM
I use Avery Superior Laser Paper, 170g glossy.
I have had no problems with coating sticking, nothing that didn't come off by the touch of a finger after it's been soaked in water.
The problem with magazine paper was for me that the original colours from the magazine came off and made large weird paths on the PCB.
About the supply problem... I just bought a package with 200x A4 pieces in, cost me maybe 20$ but will last for a long time :)
Killa-X
Wed Mar 09 2011, 05:15PM
I use high gloss photopaper. I just print it 'heavy'and iron it to the copper clad. White paper does stick, but if you soak it in water for a few, it will easily rub off by hand. I've been using this method with ferric chloride for over 20 boards. Even double sided. Love it!
James
Wed Mar 09 2011, 05:56PM
Marko wrote ...
Usually there are large areas of lightly colored printing so this hasn't been a problem so far. I use a bright flashlight pointed up through the paper to align it and tape together a little sandwich.
If you find your boards are getting pitted, try shaking the toner cartridge or fiddle with the printer settings to get it to lay down more toner. The printer/toner is the greatest variable.
Killa-X
Wed Mar 09 2011, 06:17PM
Also you can touch up any spots that didn't transfer ith nail polish. Works great, only con is it takes a little more steel wool scrubbing to get the nail polish off, compared to the toner.
Wed Mar 09 2011, 07:09PM
Killa-X wrote ...
Hi,
So you don't even bother removing the gloss after soaking (when dried your exposed surfaces are still white?)
I did this at first but my boards would end up terrible. I found scraping all the gloss instrumental for a good pcb etch.
But one thing I suspect now is that it might be due to acid damage to the toner/gloss. If the pcb is left in muriatic acid for half an hour heavy damage will start to appear, and after a few hours entire print will come cleanly off it.
Should I perhaps try ferric chloride for this reason? It might be a slower and messier etch but worth it if I don't have to scrub the gloss. It might still such, though. Anybody tried comparing different etchants with the technique?
I do that too. The fact that I keep nail polish in my room puzzles people nevertheless.
James
Wed Mar 09 2011, 07:42PM
Marko wrote ...
Killa-X wrote ...
Hi,
Try the magazine paper, it works well. I tried the sticker backing last night after someone mentioned it and it does indeed work well, the paper just fell off coming out of the laminator and left the toner on the board. The magazine paper is almost as good and a lot cheaper though.
Killa-X
Wed Mar 09 2011, 10:25PM
Marko, when i use gloss paper the only stuff left behind is white paper. All i do is soak it and rub it off with my hand. NOTHING is left on the board except black traces..comes off very easy in my case.
James
Thu Mar 10 2011, 12:53AM
Perhaps he's overheating it and melting the plastic? A clothes iron is too hot, I used one in the past but got widely inconsistent results. A $30 laminator with a simple modification worked FAR better.
Killa-X
Thu Mar 10 2011, 12:58AM
James wrote ...
I iron using the highest settings. Linen or whatever. I usually press the iron down on the clad for 15 seconds straight, nose rube the board, 15 seconds again, nose rub, 15 again, done.
