  • Guests: 50
How to get a singing arc to work - from a fly back - help needed
JamesH
Mon Mar 07 2011, 07:23PM Print
JamesH Registered Member #579 Joined: Mon Mar 12 2007, 09:45AM
I have tried to do this lots of times - and I did have one working in a fashion once
I have a nice flyback driver set up with NE555 and two paralleled Mosfets
It works well and is silent with 30 mm arc
The audio is neg rail and nO5 pin on the Ne55 via a 474 cap
I also have a 0,01 cap to ground - decouple
I can not get a peep out of it
Do I need a lot of volts to drive pin 5 on the timer chip?
Do I need more audio V than my Mp3 player or my android can supply ?
Thanks in advance for any help
Mon Mar 07 2011, 08:06PM
IIRC the 555 needs to be biased between 1/3 and 2/3 Vcc to get any significant change in frequency and pulse width.
So for an input voltage of 12V the signal would need to be centred at 8V and be 3V p-p in order to change the frequency by the needed amount.
Another method is to leave the frequency alone and change the average current in the arc which is done by altering the available input current with a series MOSFET in the power line.
This approach is used on CCFL inverters on monitors, and results in a near 100% brightness control when the lamp current is part of the feedback loop.
-A
Tightmopedman9
Tue Mar 08 2011, 11:23PM
Tightmopedman9 Registered Member #3197 Joined: Tue Sept 14 2010, 04:56PM
Conundrum wrote ...
-A
Could you explain this in a bit more detail? Sounds interesting
Inducktion
Wed Mar 09 2011, 12:19AM
Tightmopedman9 wrote ...
Conundrum wrote ...
-A
Sounds sorta like an SCR dimmer circuit with modulation...
JamesH
Wed Mar 09 2011, 08:00PM
thanks for the replies - especially conundrum
Whoopee
I now have got one working for more that a few minutes
I have made some circuit changes - neon across the primary coil and some extra diodes . I will post circuit and video soon for others
The Audio input was increased - as conundrum suggested ........... I got a alarm radio from ASDA ( USA = walmart) for £2 ( approx 3 USD.)
mains operated , and wired in an audio out socket as there was not one built in
It works well at the moment
I will try some other circuits later but for now I can show it at the talk I am giving to-morrow
Thanks all
