  • Guests: 86
Troubleshooting my first DRSSTC
hsieh
Sun Mar 06 2011, 01:45PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
I finished my first DRSSTC but it dosen't work at all.there is no spark and nearby fluorscent lamps didn't lignts up.
I scoped the output of the driver section and found that it is not oscillating and there is no output.I tried to reverse the connection of my primary coil but still can't make it resonant. I ground it to main ground.I checked my wiring and currently didn't find out why.
I use steve ward's DRSSTC.5 design
I will upload my PCB design tomorrow.My computer didn't have altium so I have to use it at school.
1299419123 1412 FT0 Dscn8025
1299419123 1412 FT0 Dscn8027
1299419123 1412 FT0 Dscn8028
1299419123 1412 FT0 Dscn8029
Gregory
Sun Mar 06 2011, 04:13PM
Are you sure your LC primary tank is ressoning at the ressonator frequency?
Sun Mar 06 2011, 05:31PM
Try to get it working as a SSTC first.
Try reversing the primary connections and also the feedback CT connections and the primary GDT connections. Make all the combinations for this three parameters at low voltage input with a neon lamp to see if it oscillates.
The yellow toroid from the feedback Ct seems to be from a RF supressor (possible iron powder core). Maibe this is the trouble.
Verify again the circuit layout if it is correct.
hsieh
Mon Mar 07 2011, 12:28AM
My PCB layout
1
2
Mon Mar 07 2011, 03:40PM
You do not supply us with ALL the information about EVERY single component in your coil, so it is impossible to help you without guessing...
Ill start with... the bottom diode substituting the IGBT body diode, why is it connected with its middle leg to the mmc/primary coil loop?
hsieh
Tue Mar 08 2011, 12:02AM
Mads Barnkob wrote ...
I know I make this mistake.But later I found that the pin 1 of that diode is also connected to IGBT in my PCB.My TO-247 diode has only 2 pins.
What is the other necessary information?
