  • Guests: 54
01/04 bomberguy92 (34)
01/05 Timo (40)
01/06 Ash Small (63)
Flyback (collaboration) for Corona, Insulation, Waveform purposes.
1 2 3 4  last
Sun Mar 06 2011, 04:08AM Print
OK, here we go...
Purpose: This device will replace my NST and Iggies for corona production, solid and oil insulation chartacterising, and O-scope waveform viewing, and cool pics---possibly burning stuff for fun too.
Implementation: A 555 timer configured for independent high and low driving of a IGBT or MOSFET, switching About 50-60Vdc at 2-3 Amps through the after-production primary.
GOAL: Hopefully 30kV at 200 Watts or there abouts.
Link2 Good 555 timer circuit site.
]htg7n60a4d.pdf[/file] IGBT
]stw13nk100z.pdf[/file] MOSFET
1299387435 2431 FT1630 Lm555basics4
555 PWM indepentent high and low. From the above cited web page.
1299384517 2431 FT0 Flyback1
Initial build, aluminum Plate: 7.5" x 7.5" x 0.25"
1299384517 2431 FT0 Flyback2
35kV flyback, crack should not matter as the core is gapped anyway.
1299384517 2431 FT0 Flyback3
I'm considering cutting these pins to half hieght, then epoxing them in. I tried to solder "Ball" that lead such that the field intensity will be reduced due to lack of sharp solder points.
1299384517 2431 FT0 Flyback5
I will start with 10 turns, at 60 volts, im sure it wont take much on-time to cause saturation. Eventually I will enclose this whole flyback in acrylic and an oil tank.
1299384517 2431 FT0 Flyback6
Flyback, Cap bank, LV transformer (60Vdc @ 2A), TO-247, Bridge rect, and 555 PWM--PCB.
1299384517 2431 FT0 Flyback7
Flyback (1 of the 3 I bought from Killa-X)
Inducktion
Sun Mar 06 2011, 05:48AM
...why not use a half bridge driver? Or is that what the 555 timer is achieving?
If you use a resonant capacitor the output should be a bit higher, depending on the resonant frequency and the frequency output by the 555 timer. A half bridge version of this should work too. Why not use a GDT or something? o:
Sun Mar 06 2011, 05:54AM
Inducktion wrote ...
Trying to keep it simple for first device version, but would a push-pull / half bridge do any good with diodes in series throughout the secondary?
Killa-X
Sun Mar 06 2011, 06:53AM
Well, good luck with the project! Let me know if that core starts to cause any issues though. I may plan a 3 series ZVS someday but I will keep a track on your progress and see if I will try it my self for fun!
Sun Mar 06 2011, 10:06AM
Patrick wrote ...
...but would a push-pull / half bridge do any good with diodes in series throughout the secondary?
Not really, you're better off driving these diode split flybacks in flyback mode. Push-pull should be used with full-wave or unrectified flybacks.
Sun Mar 06 2011, 10:26AM
I see two major reliability problems;
200W @ 30 kV = 6.66 mA = overheated secondary winding (3 mA/90W is ok)
driving the lopt primary with a symetrical primary waveform will produce a symetrical secondary waveform, so the stress on the internal diodes is 60 kV total (more with internal 'ringing') = over-volted diodes.
Since you're in the land of 110 Vac (or thereabouts) full-wave rectified mains is perfect for supplying a lopt in conventional flyback mode (as they were designed for)
You will need to isolate (pulse-transformer or opto-isolator) the lopt primary drive circuitry from your low voltage drive circuitry (555 etc.) and connect the 'bottom' end of the secondary to a reliable earth (Protective / mains earth) for safety and ease of experimenting.
With a couple of divide-by-two flip-flops you can drive four lopt with a mark:space ratio of 3:1
(this provides four pulses per 'cycle' for low output voltage ripple)
driven at variable frequency for output power control. This would give 200W RELIABLY.
Don't forget that when there is little load on the output the power that you're driving into the lopts has to go somewhere. I would put a fast >1500V diode from each primary to a 200W voltage clamp, I'd use 20 parallel strings of 3x1.5KE350CP TVS because I've got a lot of them, you would need something equivalent
(e.g. zener diode string to the base of a transistor that can take 200W @ 1.5 kV)
Sun Mar 06 2011, 02:53PM
Uzzors wrote ...
Patrick wrote ...
I will be using the normal single switch flyback mode with TVS's, as I dont want my internal diodes blown out...I see no need to use a symmetric +,- waveform.
James
Sun Mar 06 2011, 08:12PM
Don't forget to use a snubber when driving these things hard in flyback mode. There's a good app note here: Link2
Note that quite a lot of power can be dissipated by the snubber. I once used a 60W 120V incandescent lamp in place of the resistor and was able to light it brighter than full brightness from about 40V into the circuit. Measured 76kV out of the SVGA monitor flyback though.
Inducktion
Sun Mar 06 2011, 10:00PM
Uzzors wrote ...
Patrick wrote ...
I meant using a half bridge driver so that you have two mosfets sharing the load equally. It would reduce strain on the fets and allow for more power right?
Mon Mar 07 2011, 03:13AM
New work
1299467600 2431 FT110121 Flyback9
7" tall acrylic oil tank, insulators, and flyback. Also seen, 75 M ohm 20kV resistor.
Does anyone know how well acrylic resists surface carbon tracking? (relative to other plastics: good, fair, poor?)
1 2 3 4  last
