  • Guests: 52
01/12 RoV IW3IPD (63)
Another mystery photo
Dr. Shark
Wed Jun 07 2006, 07:42AM Print
Guess what:
1149666101 75 FT0 Feder
and once you got that, feel free to share your theory as to _why_ this happens.
Desmogod
Wed Jun 07 2006, 08:03AM
Laser on a feather.
Dr. Shark
Wed Jun 07 2006, 08:48AM
OK, thats the easy part. Now, why does the green laser flouresce yellow?
Wed Jun 07 2006, 11:30AM
Its a property of the material, not the laser.
Dr. Shark
Wed Jun 07 2006, 12:14PM
Thats true, obviously. Still I wonder what kind of dye could be in there causing this. I know that ruby laser rods supposedly absorb 532nm to reradiate at their 706nm or whatever, and some dyes like flourescine do it too, but this is the only household item I have noticed this kind of flourescence with so far.
Wed Jun 07 2006, 02:01PM
Just about anything that floresces a color of a lower wavelnegth than green will glow when hit by a green laser... Red/yellow reflective stripes, some toys, etc
I would expect that band on the feather glow red under a uv light...
Dr. Shark
Wed Jun 07 2006, 05:29PM
Most flourescent materials require pumping in a more or less narrow wavelength range, often in the UV, but not always (YAG laser rods are an example that absorbs at 808nm and floureces at 1024nm). Therefore I don't expect too much things to act in this way, incidentially, I don't know many flourecent materials anyway... Maybe TDU could point a green Laser at his flourescent scorpion? smile
wrote ...
Umm, which band?
Bored Chemist
Wed Jun 07 2006, 06:47PM
Most things fluoresce. The question is whether or not the emitted light is visible- it often isn't, whether the efficiency is high- it's often lousy and whether the pumping radiation is commonly available again, not often.
Bjørn
Wed Jun 07 2006, 09:31PM
The human body fluoresce in visible light, it seems like many things that are alive or have been alive also does to some degree. A flash of about 10 J for every cm^2 will make a quite surprising display if your eyes are at the most sensitive. Remember to close and cover your eyes and don't peek until after the flash.
Wed Jun 07 2006, 10:48PM
joe wrote ...
Umm, which band?
The part of the feather that is turning the green laser light yellow wink
Here is a pic of my green laser on a piece of red fluorescent tape...
1149720511 56 FT11012 Img 1734
and hitting a florescent piece dye in in a galileo thermometer
1149720511 56 FT11012 Img 1745
