  • Guests: 51
Fabio (46)
Corey (35)
02/04 Fabio (46)
02/04 Corey (35)
02/05 teslaguy (36)
Pulsed power buck converters for DRSSTC drive
Marko
Thu Mar 03 2011, 08:24AM Print
Hi guys,
I'm just curious, how far did the whole thing advance since steve ward's giant sucess with the idea? Anyone built similar things in meanwhile? I'd like to try something like that one day and I'm wondering where to start - like any articles I should go through, and controller chips to look after?
Marko
Thu Mar 03 2011, 10:39AM
Hi Marko
My research interest right now is using sigma-delta modulation of the gate drive to do away with the buck converter part of the QCW altogether. My PLL driver already does that, it dithers the gate drive on and off to keep the primary current at the level you set, and I've proved that my coils work reliably in that mode: the demo coil I built for Shanghai ran for 2 weeks bouncing off its current limiter.
So, in theory all I need to do is substitute a ramp waveform for the current limit pot. My 555-based interrupter already has a ramp waveform in its guts, so it should be easy enough.
I discussed it with Steve Ward, and he thinks it will work.
Goodchild
Fri Mar 04 2011, 06:46AM
I have been working to duplicate the QCW for about 4 or 5 months now and from what I have found the primary current stays relatively constant threw out the duration of the burst. As shown in this scope shot Link2
From what I have gathered you do need the ramp in voltage to obtain this sort of operation but this is just my opinion I could be totally wrong.
You can take a look at my flikr page Link2 for my ideas and such from my work with the QCW.
Good luck
Marko
Fri Mar 04 2011, 02:08PM
Hi goodchild,
I'm more interested into the buck converter itself for now just due to it's coolness factor. I would also like to be able to use it for rail modulation of various stuff. I've built a linear circuit with a PNP BJT, but I don't think it's powerful enough to do pulsed modulation (even for a miniature drsstc).
I'm surprised to see you simply using a TL494 for this, I thought some fancy controllers and feedback stabilization would be required. What is the reason though that you used the bottom IGBT as well - I would think it would never conduct any current as all would be handled by it's diode.
I was thinking about using high side switch only with an optocoupled isolated driver and a single high side switch, and one freewhelling diode. I didn't know that such a simple controller arrangement (without current mode control) would work here for high pulsed power conditions, though.
For acheiving the effect on a tipycal (non-pll) DRSSTC, I was thinking to use a microcontroller to measure the current and toggle the drive on and off at a certain level, while also acting as an interrupter.
Marko
Goodchild
Fri Mar 04 2011, 03:12PM
I don't use a TL494 any more but I did at one point and it worked ok. The low side IGBT is mainly there to brings the ramp back down after a burst. If you look at some of my scope shots you will see that there is a downward ramp as well, that's just shorter that the ramp up. This brings the voltage back down slowly so that you don't get any flash overs or other nasy operation for bring the voltage back to 25VDC instantaneously.
Yes I did say 25V, you have to have the converter "rest" at a voltage above 0V to help the thing start to oscillate at the beginning of a burst. (note this is for primary feedback type designed)
Marko
Fri Mar 04 2011, 03:41PM
Goodchild wrote ...
Hi -
I'm not sure if I understand this, why would the bottom igbt be required to ramp-down the voltage? 'classic' buck approach can still do that with feedback as the load acts to lower the voltage. IMO your design looks just like a synchronous buck, but with igbt's instead opf mosfets - which can't conduct in reverse and hence the bottom igbt does nothing, it's diode carries all the current. Looking at your schematic I would think that you can take off the drive from the bottom igbt and the circuit should still work the same. (?)
Which controller are you using now, by the way instead of tl494?
marko
Sat Mar 05 2011, 12:53PM
Hey Marko
The synchronous buck is necessary because Steve Ward used it. smile
I assumed it was needed because the H-bridge has lots of RF bypass capacitance on it. To make an accurate waveform, the buck has to be able to discharge those caps as fast as it can charge them. When discharging, the bottom IGBT does pass current, which gets fed back to the DC bus cap bank.
Put another way, the synchronous buck can pass current in both directions. When conducting in reverse it acts as a boost converter. It's often used as a DC motor drive where it allows regen braking.
Marko
Sat Mar 05 2011, 02:47PM
Interesting, looks like I could get away with an sg3525, a gdt and a half bridge brick quite well then?
Only worry left is the inductor - goodchild's one looks really small for any serious peak current! I thought of using ana ir cored inductor but a 500uh one would be rather big. Also, this circuit seems to run in discontinuous mode to me, hence I can't use a powdered iron toroid for the inductor core (has to be gapped ferrite/air core?)
Thanks a lot guys,
Marko
Sat Mar 05 2011, 02:58PM
I've seen this mode referred to as "forced continuous current" mode. The inductor current is actually continuous at all times: if the current drawn by the load is less than the troughs of the inductor's ripple current, at which point a normal buck converter would go into discontinuous current, then the inductor current goes straight through zero and turns negative.
Same as a Class-D audio amp. When one of these is idling, the current delivered to the speaker is zero, but the inductor current is a triangle wave of an amp or two, symmetrical about zero. Class-D amps are made this way to avoid a transition between discontinuous and continuous current, which would cause a lot of distortion.
Marko
Sat Mar 05 2011, 04:39PM
Steve McConner wrote ...
So even though the converter always runs in continuous mode, I presume there's too much ripple to use powdered iron cores?
marko
