  • Guests: 48
Homemade caps...
Inducktion
Thu Mar 03 2011, 04:18AM Print
Hey guys. Just experimented with some anti static bags I had lying around. I had looked up what they were made of, metallic film, which is a type of capacitor. So, I quickly made a capacitor using cut sheets of anti static bags and aluminum foil. I got a 100 pF cap from roughly 7 or so layers. Not bad huh, especially considering I made this at 11 O' clock in kind of a mess.
JCM
Thu Mar 03 2011, 10:41AM
JCM Registered Member #3559 Joined: Sun Jan 02 2011, 01:19AM
Is the metal film on one side of the bag material? Or is it a homogeneous material?
radhoo
Thu Mar 03 2011, 11:34AM
See this short tutorial on homemade caps: Link2 , Might prove useful.
Inducktion
Thu Mar 03 2011, 03:51PM
I knew you can make caps out of plastic sheets and stuff, but this was just a sort of "reuse and recycle" dealio here. It just kinda fascinated me that it worked.
Fri Mar 04 2011, 03:09AM
Inducktion wrote ...
I know what you mean. As a matter of fact, plastic plate dielectric caps have proven to be pretty good. Each layer insulates a few tens of KV, and each are around 1nf each. Read this thread, they could be used as pulse caps if you really wanted, and stacked caps have low ESR and ESL Link2
If you want a big homemade cap for Tesla coil duty, buy some polyethylene plastic in the paint section at a home improvement store. It is around 4 mils thick, 4 layers should be fine for at least 10KVAC, right?
Fri Mar 04 2011, 04:21AM
Arcstarter wrote ...
4 layers of 4 mils is 16 mils, which if you use the 500V per mil number, I get 8000Vac. Of course these things always need to be tested. Like with a MOT and thin plates, then see what the punch through is.
Remember (for solids):
--dielectric strength increases with the increase in thickness of the insulant. (Directly proportional)
--dielectric strength decreases with the increase in operating temperature. (Inversely proportional)
--dielectric strength decreases with the increase in frequency. (Inversely proportional)
--dielectric strength decreases with the increase in humidity. (Inversely proportional)
