  • Guests: 41
Autonomous motion sensing laser turret for object path tracking
HazzWold 1993
Sun Feb 27 2011, 11:54PM Print
Does anyone here have any info on, or any tips towards making a turret similiar to this one Link2 but instead of controling it, having it running autonomously via a motion tracker? i would like to build one to track objects through a specific area with a 50mW green laser module, and record the path by having a camera running a long exposure of the target area.
big5824
Tue Mar 01 2011, 12:28PM
i did it using a pc sending serial data to a pic, which in turn controlled two servos for the turret, with a program based on this getting me the coordinates to aim at.
Bjørn
Tue Mar 01 2011, 03:04PM
A 50 mW green module is not really safe enough for such use.
Why would you want to record the path? If you have a motion tracker the path is known so you don't need the laser or the camera.
radhoo
Tue Mar 01 2011, 04:48PM
I've implemented a simple motion detection algorithm that works well, for a different purpose, see here:
Add that to this laser-spot following robot:
And you might get what you need.
Tue Mar 01 2011, 05:42PM
Bjørn wrote ...
What kind of laser or power would be less* dangerous, Bjorn?
*(Notice I did not say SAFE, but LESS dangerous.)
Bjørn
Tue Mar 01 2011, 06:59PM
Here are some details about laser safety: Link2
Many cheap green laser modules also spews out a huge amounts of infrared light that can be very dangerous at short range.
Tue Mar 01 2011, 10:59PM
Bjørn wrote ...
Excellent.
HazzWold 1993
Wed Mar 02 2011, 12:13AM
The particular module i have spare is IR filtered and is the lowest mW i have available. As for my purpose 200mW would be over the top. This was just for some photo ideas I had in mind. Thank you big5824 and radhoo, those links are a great help, and thanks Bjørn for the safety concerns, i do however have several pairs of 532nm blocking goggles and i didnt intend to be in very close proximity to the activated laser anyway.
