  • Guests: 36
nitromarsjipan (2025)
mb (32)
Joyeep (33)
11/05 Capper (61)
11/05 cereus (74)
11/05 Mcanderson (44)
Voltage booster
Michalis.Biochem
Wed Feb 23 2011, 08:10PM Print
Michalis.Biochem Registered Member #3340 Joined: Wed Oct 20 2010, 07:28PM
I was looking for a way to make a small voltage booster for a portable power suppy. I want to covert 3 volt dc to about 450 volt dc. While browsing the net for info i came across this video. What would the components be if i want to make something similar to his desing?
hboy007
Wed Feb 23 2011, 09:29PM
voltage multipliers and flyback / forward converters don't mix. The video you mention also suggests using a MOSFET. Since these devices need a few more volts as gate voltage to work properly, start with an LMC555 (C denotes CMOS version) that generates both the gate control clock and an output suitable for a charge pump. Then you may still consider a double-ended topology.
You could as well build a resonant royer-type converter (the urban language term for the MOSFET version is "ZVS") and supply >10V to the gate pull-ups from the charge pump.
Michalis.Biochem
Wed Feb 23 2011, 09:32PM
I considered the zvs, but am i going to be able to power it with a 6 volt latern battery? Car batteries are pretty expensive here.
Dr. ISOTOP
Wed Feb 23 2011, 10:44PM
What is this for?
Inverters driving a transformer solve all of your problems smile
Michalis.Biochem
Thu Feb 24 2011, 07:16AM
This is for a small Marx Generator.
Hmm, i have 2 transformers right now, i think they were 220 to 3,7 so by using something like 7-8volts i would be able to attain the voltages i want. But what about the inverter circuit, how do i make it?
Muttyfutty!
Thu Feb 24 2011, 09:27AM
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
450Vdc is really not suitable for a marx; your spark gaps will need to be ridiculously precise, you're better off using a HV transformer...
Electroholic
Thu Feb 24 2011, 10:42AM
Muttyfutty! wrote ...
For low pumping voltage, the marx circuit could work with sealed gaps like lightning arrestors or solid state switchs like sidac.
Michalis.Biochem
Thu Feb 24 2011, 03:08PM
I am going to power an 18 stage cw voltage multiplier with the 450Vdc. Then the output of the multiplier is going to power the marx generator so i don't see why the spark gaps have to be so precise.
Ken M.
Thu Feb 24 2011, 04:19PM
For something like 300v or so I suggest using a boost converter a simple design will work fine follow the design like this Link2 , which includes a calculator to figure up the part values you need for desired supply and output parameters.
Electroholic
Thu Feb 24 2011, 04:35PM
Michalis.Biochem wrote ...
DC fed CW multiplier? How?
