  • Guests: 24
PYLEMET-mk2 (36)
09/21 Bill G (65)
09/21 Overclocked (38)
09/21 Edi (32)
Soldering tiny SMD ICs?
dmg
Tue Feb 22 2011, 11:59PM Print
Ive been having some issues with these very small ICs in SMD package.
To make things worse, this IC has a powerpad on the buttom that needs to be soldered for heat dissapation. (its a boost IC)
I was thinking to use solder powder and a heat source to allow it to melt and adhere (without actual contact of the heat source), as I see soldering this thing with an iron nothing short of a pain in the ass.
Does this idea sound feasable? or does anyone else have any methods for tiny things like this?
Also, other then the solder powder method, how would one go about soldering the buttom heat pad without killing the IC from over temperture?
1298419193 2628 FT0 Tinything
haxor5354
Wed Feb 23 2011, 12:04AM
im not sure if an induction heater can be used for this application. it would be awesome if there is a specific frequency that only heats up solder, that would make life much easier if you're scavenging old parts from curcuit boards
dmg
Wed Feb 23 2011, 12:07AM
sadly the more sensative logic within the IC itself will be destroyed before you even begin to heat up the solder with induction heating (as the IC probably uses gold wire bonding and will be induced with damaging currents).
Thats the thing I hate about SMDs... they are very compact and usefull.. but also very easy to kill before you even use them in your circuit. (at least I got another 10 of these chips. so I can mess up a few times)
Wed Feb 23 2011, 12:36AM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
That's not small! Solder it onto the board before any other parts, stick some paste on all the pads including the thermal one (If the pads aren't pre-tinned then tin them first with solder and remove the excess with solder wick to leave a flat surface. Otherwise they may oxidise during the soldering process and the solder won't flow) .Place the IC then stick it in a (non-preheated) electric oven (toaster oven is ideal as it heats up quicker) don't worry about temperature profiles, just whack the thermostat up to around 250C (with a toaster over that has just two heat settings then pre-heat on the lower setting for about 10 minutes then switch to the higher setting) and WATCH THE BOARD. Once you see the paste melt and flow then wait about 10 more seconds then turn the oven off and open the door BUT DO NOT DISTURB THE BOARD! when it's cooled remove it, if there are any shorts between pins remove them with solder wick. This IC was done with exactly the same method :- Link2 in this oven Link2 It didn't have a thermal pad but the principles the same.
If you're worried about trying it or these IC's are hard to get hold of/expensive then get some cheap IC's that have the same package type (doesn't matter about whether they have a thermal pad or not) and experiment with them first.
Martin.
dmg
Wed Feb 23 2011, 12:52AM
Those results look great.
Ill try that for sure, thank you very much.
Adam Munich
Wed Feb 23 2011, 12:55AM
Make it a DIP!
1298422476 2893 FT109354 Dsc09595
Patience and a steady hand is the only advice I have to offer.
dmg
Wed Feb 23 2011, 01:11AM
A steady hand? that I have.
Patience to solder it like you did? not so much.
I figure Ill use a PCB and go from there using martin's method.
Bmp
rp181
Wed Feb 23 2011, 01:34AM
Drag soldering those works pretty well.
Especially for those large quad packages. Don't need solder paste, and its quick and clean. Actually pretty easy (my first SMD was drag soldering a .5mm pitch 64 TQFP).
Any tips for a .4mm pitch connector? His my limit today...
haxor5354
Wed Feb 23 2011, 03:37AM
you're lucky to have the pins on the IC exposed. how are you suppose to solder ICs that have solder joints under the chip it self?
cjk2
Wed Feb 23 2011, 03:54AM
Those are fun! Much easier than the QFN's. I use an Aoyue Int. 852A++ which is a Hakko clone to do hot air reflow. I suggest using lots of no clean flux and a good heat source set to around 350 Celsius. have a look here, the video is for a QFN, but this will apply to you as well because you have a thermal pad.
http://www.youtube.com/watch?v=c_Qt5CtUlqY
Edit:
Some more suggestions: An engineer once told me that he sticks a big (0.1") though plated hole right under the thermal pad on the chip and simply sticks an iron in there and solders the pad to the thermal pad. You can also try using a hot plate or toaster oven to reflow the part. I have not tried this method as I use a hot air tool, but others have had good results with this.
