  • Guests: 36
Elliott (35)
Gratitude (40)
Swraka (37)
12/27 Elliott (35)
12/27 Gratitude (40)
12/27 Swraka (37)
sstc topload
tritium
Sat Feb 19 2011, 06:12PM Print
tritium Registered Member #2591 Joined: Fri Jan 01 2010, 11:58AM
hello coilers,
I have a secondary coil, fres is 770 khz without topload, is it possible to lower the fres by using a hv-capasitor instead of a toroid, with a toroid of 7 pf i have a fres of 412 khz, but i need to go below 200khz.
it is a small coil:
140mm long
50mm diameter
1000 turns @ awg38
I wan't this thing run in cw-mode.
nem96
Mon Feb 28 2011, 10:31AM
nem96 Registered Member #3722 Joined: Sun Feb 27 2011, 03:26PM
Why don't you try (much) bigger topload?
tritium
Mon Feb 28 2011, 04:47PM
because it has to be small, the sec. voltage output is 30kv so I toucht just put a high voltage cap to the output, but I think this will not work because it is in serie with the topload of 7 pf and than:
1/ (1/c1+1/c2)=total and is less than 7 pF
I think it is verry differcult to make a small coil like this to lower the fres below 200Khz
maybe an capacitive earth shield around the sec. coil will do with some distance and isolation of course, but I think that is a bad idea.
a long small ferrite in the center of the sec. is allso an idea, but than it is not a tesla coil anymore cry
any suggestions are welcome. wink
Mon Feb 28 2011, 05:22PM
I think you'll have to wind a new secondary using thinner wire! But seriously, I don't see why 400kHz is a big issue. I've made coils which run at both 500 and 600kHz, using common components in a half-bridge and fullbridge, without issues.
tritium
Mon Feb 28 2011, 05:38PM
Uzzors wrote ...
also at cw-mode ?
edit:
thinner wire is a hell to wind...
i am seeking for alternative things, maybe a hv cap across the full secondary will do...
edit2:
yes it does, 50 pf will drop my res.freq. to 180 khz, so I am going for a try to build this cap, I have a lot of 2KV/100pF caps, and they are small enough to put them inside the coil, I don't know if they like it inside this coil but I give it a try cheesey
Mon Feb 28 2011, 10:29PM
tritium wrote ...
Uzzors wrote ...
also at cw-mode ?
Yes. Streamers aren't too impressive, but I built it to last, meaning very little stress on components. Link2
