  • Guests: 61
quality of Lafayette DMB-USB2
TheMerovingian
Sat Feb 12 2011, 04:20PM Print
I came accross this multimeter for 99Euros at ebay. It says true-rms but i don't trust it. It is worth buying? Anyone has it?
Adam Munich
Sat Feb 12 2011, 04:43PM
I can't find any info on that meter, but may I suggest this one? It was an amazing meter until I killed it... Link2
TheMerovingian
Sat Feb 12 2011, 07:26PM
How did you kill it?
Adam Munich
Sat Feb 12 2011, 08:55PM
Lots o' volts.
Sat Feb 12 2011, 10:46PM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
What reason do you have for not trusting it ?
TheMerovingian
Sun Feb 13 2011, 02:12PM
Because it says it is true-rms and then says that the waveform must be sinusoidal.... maybe they mean it must be alternating, who knows... i have to use my oscope math to get the rms reading
Sun Feb 13 2011, 03:23PM
Ah! Email them and ask for clarification? BTW if True RMS is important to you then this is worth a read Link2
Martin.
Sun Feb 13 2011, 04:27PM
We've discussed that before. All "true RMS" meters are like that by design, even though it's not technically true RMS. I've never seen one that took the DC component into account, if it did then it wouldn't even make sense to have separate AC and DC ranges on the thing. They would have to be called "RMS" and "Average" instead.
For 99 euros I'd rather buy a second hand Fluke.
TheMerovingian
Wed Mar 02 2011, 04:15PM
Good point. I received the multimeter and it works correctly but , as pointed out, with simmetric waveforms. Fortunately the (FalseRMS^2 + DcAverage^2)^0.5 is a good workaround. For the rest , my Digital Scope will easily calculate true RMS (if i use DC and not AC coupling :D)
Nicko
Wed Mar 02 2011, 04:35PM
Steve McConner wrote ...
Tek DMM916 - Link2 - See page 1-24
