  • Guests: 85
drsstc musical using microcontroller help?
Itstrevor
Sat Feb 12 2011, 07:23AM Print
Itstrevor Registered Member #2398 Joined: Mon Sept 28 2009, 02:57AM
I'm using an msp430 microcontroller hopefully fulfilling the same function that my xenosonic audio board was supposed to do (but the xenosonic for one reason or another did not work properly so I want to take a digital approach). can anyone help?
Gregory
Sat Feb 12 2011, 03:45PM
I'm actually using MIDI interface to send the notes to the uC. MIDI will say when play and stop and what note the uC need to play. In the uC I programed a array with the notes and used a timer to generate the square wave that go to the DRSSTC. With two timers I can play to notes in same time. I think that this is the best method to do this. You can read about MIDI here: Link2
Itstrevor
Sat Feb 12 2011, 08:51PM
has anyone already got some code?
Gregory
Sat Feb 12 2011, 09:01PM
Yes, we have, but the code is the soul of a MIDi system, the hardware is very simple. I think that nobody will send the code.. I gave for you one website that say all about MIDI. Before ask the code you need to try yourself!
Itstrevor
Sun Feb 13 2011, 09:14PM
Blearg but Ive already burnt out so many IGBTs and I dont have much money left
Gregory
Sun Feb 13 2011, 10:40PM
Before try audio modulation you need to run your coil ok with a normal interrupter man oO and after you start to develop a midi intettuper.
Itstrevor
Mon Feb 14 2011, 03:42AM
I already have an interrupter on my coil but i have a bypass switch and i want it to run off of the microcontroller
Coronafix
Mon Feb 14 2011, 11:58AM
Itstrevor wrote ...
Then you should stop and do more research.
