  • Guests: 50
CNC plans
Adam Munich
Sat Feb 12 2011, 04:55AM Print
Anyone know of any good CNC plans? I'm looking for something small, maybe a 12"^2 working area. It needs to have very little backlash because I plan to mill PCBs with it, possibly even SOP chip surface mount. It also needs to be powerful enough to mill plastic/wood.
So... anyone know of some good CNC plans? Also, my working material is going to be wood or mdf.
Hmm... so many projects at once. flamethrower, X-ray, now a cnc possibly.
Sat Feb 12 2011, 05:05AM
I was disgusted with the crap plans for sale in the back alley's of the net so I enginneered my own, entirely of my own design. my advice---build a stiff quill with a motor thats variable from 4k-15k, 1Hp or better.
Also, use servos if you can affford it, steppers if you cant, that is my one great regret. Shouldve used servos, such a fool I was.
or copy Dr.H.'s -> Link2 if you plan to do PCB's id build his.
His is better then even mine, at least talk to him before you buy/build anything!
Carbon_Rod
Sun Feb 13 2011, 05:37AM
Unless you plan to build something as a learning exercise it will cost you more.
These are actually quite nice, and if you are lucky a 4-axis mill can be found used on ebay.
The PCB island tool path generator for Eagle PCB:
Cheers,
Rod
Adam Munich
Sun Feb 13 2011, 06:41AM
More than $700? Link2
And I don't use eagle, can't figure out how to. I use diptrace which supports dxf export. I can turn the dxf into g-code or something using one of those fancy programs.
Sun Feb 13 2011, 07:56AM
Grenadier wrote ...
I use Kcam, AutoCAD 2007. But I dont make many PCBs.
Dr. H.
Sun Feb 13 2011, 08:18PM
Good day guys
achieving SOP accuracy is quite a challenge - furthermore you are planning on using "wood" .... you will have to use anti - backlash nuts (witch won't be a big problem to make or buy) but accurate linear bearings is a must (and when you spend money for such bearings you could easily afford to use aluminum for building material (also it is quite a small mill). The motion drive - steppers are best for first project (and you CAN achieve great accuracy with them). For driver - I have build quite a few of the "Linistepper"s and they work perfectly. Also have used chopper type ICs but are harder to find. But if you want real accuracy - servos (and you have a closed loop then) - but be prepared to spend much more cash on good servo (motor + encoder) and driver.
All in all - it is always a compromise between working area accuracy and milling power when you build a budget mill.
Cheers smile
Sun Feb 13 2011, 09:12PM
I use the L297H ic, and the L298 ic from STmicro. I've never had a problem with either for stepper-motor control, guess you could buy ready made gecko's which are nice, for rich people. The L297H is the power ic, driven by the l298 which is the logic ic. You can make your circuit as complcated with many fucntions, or as simple as only step/dir.
Mon Feb 14 2011, 10:56AM
Martin King Registered Member #3040 Joined: Tue Jul 27 2010, 03:15PM
Bosch Rexroth extrusion is good stuff to make small CNC machines from. Quite expensive new but there are people selling bundles of if (from old dismantled machines or off-cuts) on EBay e.g. Link2 It also has the advantage that if you want to make a bigger machine later you can dismantle the old machine and re-use many of the parts it's a bit like big boys Meccano smile. The T-slots and nuts also make adjustment and squaring up easy although you still need to be able to cut it squarely and accurately to get good results.
Martin.
doctor electrons
Tue Feb 15 2011, 02:58AM
you can also check out 8020 and frameworld, its all pretty much the same stuff. If youre interested i have some polyphase steppers with
the drive and a few robocylinders with the drive as well. I also have some plcs and power supplies. I was going to do exactly what your plans
are with them. Shoot me a pm and i can give you more details about the goodies. OR i can post them in the sale and trade thread.
Adam Munich
Tue Feb 15 2011, 05:41AM
Hmm....
Well my main goal is to mill PCBs as cheaply as possible, and I figured building a CNC would be cheaper then that buying that zen kit. So you guys are convinced that it'll cost me more?
I suppose I could always start a PCB milling service to make the money back though... mill a PCB for $5 + the cost of the copper clad or something.
