  • Guests: 85
Issues about IGBT protecting diode using
steven968
Fri Feb 11 2011, 08:42AM Print
steven968 Registered Member #3516 Joined: Wed Dec 15 2010, 10:40AM
Hi guys,
A SSTC which driven by full bridge IGBT HGTG40N60B3 (TO-247 footprint), input voltage is 250v above 20A,Steve Wards' miniSSTC driver. The IGBTs don't have protection diode so is MUR1560 (600v 15a) capable for using? Do I need to add bi-polar zeners between gate and emitter?
Cheers.
Gregory
Fri Feb 11 2011, 05:03PM
1- The MUR1560 is capable and will run ok!
2- The best way to protect the gates is putting zener, but don't need to be bipolar, you can use two normal zener in anti-series mode.
Goodchild
Sat Feb 12 2011, 08:27AM
TVS work great for protecting the gates as well.
