  • Guests: 49
marks aerosol generator
Antonio
Mon Feb 14 2011, 01:52AM
A million volts would require quite large structures to contain the charge while it grows. It's difficult to obtain more than a few hundreds of kV, and the main reason is the degree of insulation required. You always end with something as a Van de Graaff generator when optimizing the structure of an electrostatic generator for the highest voltage in a limited space.
Microwatt
Mon Feb 14 2011, 06:25AM
here is a version here.
1297664699 3282 FT108350 Vortex
william L
Mon Feb 14 2011, 08:13AM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
All that is going to happen is that the "feedback" Will directly arc to the ground point. However, your going to need superconducting water to achieve such a voltage. That is only even theory itself. You can't just amplify power in a loop.
Mon Feb 14 2011, 08:18AM
What would superconducting improve? I doubt very much that this would scale up easily, it is interesting for academic and demo purposes though.
william L
Mon Feb 14 2011, 08:25AM
The superconducting thing is that if you had a ring of superconducting material, (or other non-canceling-loop)
you could sustain a charge forever, assuming perfect conditions, or until inductance took over. this would however, require the charge to be implemented magnetically. So really, I guess there is almost no application besides "academic and demo purposes"
Antonio
Mon Feb 14 2011, 07:47PM
Superconductivity doesn't have any effect in the capability of a conductor in holding static charge. The inductor rings in the Kelvin generator don't consume any current or power, except for leakage.
In the drawing, two cross-connected devices would be required to implement the feedback mechanism.
