  • Guests: 85
Better method to tune
Gregory
Wed Feb 09 2011, 07:55PM Print
Hello! I'm make two big DRSSTCs, one with cm300 and another with ixys 60n60.. But i have questions about tune..
What is the best method?
- Use a low voltage on the bridge, like 50V and scope the primary current?
or
- Use total power and put the OCD to a low value, like 100A..
Can you show me pics of current envelopes in primary circuit? of a good tune and a bad tune?
Thanks!
william L
Thu Feb 10 2011, 02:49AM
william L Registered Member #3093 Joined: Mon Aug 09 2010, 11:40PM
Do you have a signal generator and oscilloscope? You don't necessarily need to run the coil to tune it. Trying to scope 100A seems rather impractical to me...
Gregory
Thu Feb 10 2011, 04:49AM
I have the signal generator and oscilloscope, will try with the normal method.. I have been had good results putting a wire on the top load to the air, like a spark, simulating the capacitive load of the spark that detune the secondary. With my small DRSSTC this method work good. Is only put a wire in topoload to air with expected spark length when measure the secondary frequency.
