  • Guests: 84
HV inductors?
hsieh
Tue Feb 08 2011, 03:03PM Print
hsieh Registered Member #1412 Joined: Thu Mar 27 2008, 04:07PM
How can I find or build the inductor describe in Richie's DC powered tesla coil page Link2
Is it easy to build or find a inductor that has several Henry or inductance and can stand several KV?
thanks
OiD
Tue Feb 08 2011, 10:10PM
OiD Registered Member #2150 Joined: Tue Jun 02 2009, 08:33PM
You could use an iron core dipped in wax or other insulation. For winding the inductor you could use standard insulated copper wire.
As for several Henry's... I don't have any ideas other than it'll be pretty big.
Coronafix
Wed Feb 09 2011, 02:20AM
Have a look at Conners DC coil.
Paul Benham
Sun Feb 13 2011, 11:31AM
Paul Benham Registered Member #570 Joined: Wed Mar 07 2007, 03:41PM
I've had very good success with using the secondaries of microwave oven transmformers. I take off the I section of the core along with the heater winding and primary, and use four in series. It gave me 14.6H and will withstand 12kV.
Dr. Slack
Sun Feb 13 2011, 05:20PM
If you can find ballast chokes from flourescent lights, they are in the order of 1H (depending on tube wattage), and are *rated* at 1kV (that's what you need to strike a tube) so should take 3kV happily. A few of those in series will do you.
