  • Guests: 69
Noelle (43)
King_of_Junk (36)
Ixz (35)
geobruce (31)
tulkas (32)
Gregory (31)
01/20 CT2 (37)
01/20 Josh Johnson (46)
01/21 Banana Man (41)
Math Proof
Arkin
Sun Feb 06 2011, 09:30PM Print
Arkin Registered Member #2140 Joined: Tue May 26 2009, 09:16PM
I know it isn't exactly electronic-y, but figured I would ask here, where there's a lot of smart people.
I have an assignment, and it is finding patterns within linear equations. The linear equation's coeffecience have a common difference. e.g:
x+2y=3 (difference of 1)
2x-y=-4 (difference of 2)
The pattern here is for any 2x2 equation, with a common difference, the solution is always (-1,2). For a 3x3, it is y=-2x-1, z=x+2.
The problem I have is extending it. This is what I noticed, for the y values:
3x3: -2x-1
4x4: u-2x-2
5x5: 2f+u-2x-3
Where the variable progression is x,y,z,u,f.
The pattern is that everytime, the last (n-3) variable - 1 is added. E.g, -2x-1 is a 3x3. To go to 4x4, the coefficient would be 1 (4-3), so I add u-1. 4x4 to 5x5 is a coefficient of 2 (5-3), so I add 2f-1.
Because this is so arbitrary, with out even a concrete number of terms, how would you go about proving it? My guess is somehow, a bunch of middle terms cancel out, so you only have to worry about the first and last equation.
Dr. ISOTOP
Sun Feb 06 2011, 10:00PM
What do you mean "coefficients have a common difference?"
Do you mean that if we write the system as a matrix {a_ij}, the rows of the matrix from arithmetic sequences?
Arkin
Sun Feb 06 2011, 10:10PM
yes. For a 3x3 system of equations, it would be generalized like this:
ax + (a+n)y + (a+2n)z = a+3n
bx + (b+m)y + (b+2m)z = b+3m
cx + (c+u)y + (c+2u)z = c+3u
Arkin
Mon Feb 07 2011, 03:35AM
Here is another way of saying it:
F4i
[Edit: Image size]
woxxey
Mon Feb 07 2011, 03:13PM
woxxey Registered Member #1906 Joined: Sat Jan 03 2009, 05:06PM
I think Iv'e done that assignment :P
I only extended it to a 3x3 system and proved it generally using matrices and row operations.
59 Pm
Edit: It might be wort acknowledging that the coefficients form an arithmetic sequence in Part A.
Arkin
Tue Feb 08 2011, 01:15AM
Yea, chances are you did, as IB as only a hand full =p
I already proved the 3x3, but through substitution, not row operations. I'le have to look up matrix row operations, never done much with matrixes.
