  • Guests: 52
Nikola Tesla is obsessed with the number 3?
haxor5354
Sat Feb 05 2011, 03:39AM Print
is that why he came up with an idead of 3 phase AC? confused
radiotech
Sat Feb 05 2011, 05:04AM
Tesla developed the system of a rotating magnetic field. His system was 2 Phase,
A split phase motor is not a 2 phase motor.
3 Phase came later.
Sat Feb 05 2011, 06:57AM
my favorite number is "e".
dmg
Sat Feb 05 2011, 07:01AM
My favorite number is 1
Which means my favorite number is 2
A = X
A + A = A + X
2A = A + X
2A - 2X = A + X - 2X
2(A-X) = A + X - 2X
2(A-X) = A - X
2 = 1
Problem?
HazzWold 1993
Sat Feb 05 2011, 07:27AM
GBD wrote ...
A = X
A + A = A + X
2A = A + X
2(A-X) = A + X - 2X
2(A-X) = A - X
2 = 1
Problem?
u mad?
Sat Feb 05 2011, 09:57AM
Well then, by induction, all numbers are your favourite number. Also the Pope is a Jack Russell, etc.
You can calculate the optimum number of phases for a power transmission system. It works out something like 2.7, so they use 3 because it's the nearest whole number.
Ash Small
Sat Feb 05 2011, 12:17PM
My favourite prime number is 127.
127/5=25.4
1"=25.4mm
With a 127 toothed gearwheel you can cut metric threads on an old imperial lathe with change-wheels.
Sat Feb 05 2011, 03:11PM
Well, I could if I had one, or a clue how to use it.
I shall fax a cookie to the first person to identify the bogus step in GBD's proof.
Ash Small
Sat Feb 05 2011, 03:30PM
Steve McConner wrote ...
I bought mine from here:
£15.95 inc VAT.
The teeth are 1/8" pitch, but once you have one you can make another any size you want.
The method of use is outlined here:
dmg
Sat Feb 05 2011, 03:42PM
Hint for the future cookie bearer: You cannot devide by zero.
