  • Guests: 49
I feel like Golum just looking at these photos
Fri Feb 04 2011, 10:49PM Print
This page may have been posted before but I don't recall seeing it here. Do Want!
-Dave
Fri Feb 04 2011, 10:55PM
I need to buy one of these facilities, and then make the workers do my bidding.
Sat Feb 05 2011, 12:19AM
1296864697 543 FT0 Marx China
This Chinese Marx generator is 25m high. It has 24 stages with a stage voltage of 300kV, but uses a dual supply
system to keep the voltage to Earth per stage at ±150kV. The dual supply system was developed to cope
with problems of high humidity and atmospheric pollution.
Coronafix
Sun Feb 06 2011, 09:16AM
My precious!
Looks beautiful in the snow.
Such a shame they are just rusting away.
Electroholic
Sun Feb 06 2011, 10:46AM
It just makes me want to play Red Alert 2 again.
Sun Feb 06 2011, 12:31PM
hmm.
Interestingly enough the Russian facilities were used during the Cold War, to investigate the weapons potential of particle beams.
(think SDI aka "Star Wars", etc).
Apparently they did get a working prototype just before the money ran out, of an aircraft mounted NPB (neutral particle beam) which would have acted as an airborne EMP.
Unfortunately the effect worked both ways and would have wrecked the generator and attached aircraft due to the backscatter.
-A
"Bother!" said Pooh, as his PC threw a cyclic redundancy check error...
