  • Guests: 34
07/09 Avi (41)
07/09 Jannick Hagen (15)
07/10 Sparcz (69)
100 micron Vacuum drying dielectric oil...
1 2 3 4
Tue Feb 01 2011, 07:36AM Print
I need to vacuum dry some vegatable oil to keep its dielectric strength up to its max, for a 60 kv project I have coming up. I have done some research, here on the forum and on google, but its been awhile since Ive done vacuum stuff. I would like to ask some others who might have some vacuum experience to volunteer any good ideas and anything to watch out for so I dont die in a burst vessel explosion, or such.
My plan:
--To establish a 100 micron vacuum on about 1 quart of oil in a schedule 40 well built vacuum chamber.
--Then hold that 100 microns for 6 hours or so, put the whole thing in a safe place in case of bursting issues.
--Then let the vacuum go and immediatley use the oil in the final device.
--Hopefully the plastics I depend on are suffciently water impermeable for 1-2 years at a time.
Am I missing anything super-duper important? I dont think I will heat the oil, but if any physics/chemistry buffs can confirm my thinking on this next point:
first: if a liqiud is warm/hot, then solids will be more willing to dissolve and stay in solution while warm/hot.
But dissolved gases will escape more easilly.
second: if a liquid is cool/cold, then solids will be less willing to dissolve and stay in solution while cool/cold.
But dissolved gases will be more willing to stay in solution, due to slower kinetic motion.
Is the above stated right, or am I totally off? If I am right then, which phase would polar water molecules be in, (liquid or vapor) while partially dissolved in a highly non-polar fluid like oil? Am I assured that when the vacuum is drawn that the water will be vapor and definately leave in a hurry?
Ash Small
Tue Feb 01 2011, 08:13AM
Shedule 40 pipe should be ok. It is good for 140 PSI and you won't exceed 15 PSI.
Water vapour is notoriously difficult to remove from vacuum systems. I'd imagine it would take a lot longer than six hours to remove all the water from the oil.
'Bake-out' under vacuum is often used to remove water vapour from vacuum systems, usually at temperature of between 150-400 degrees C.
I think it's probably a case of 'trial and error' in this case.
Tue Feb 01 2011, 08:19AM
I will consider what you have said, Ive learned that trace water reduces dielectric strength of oils by 50% so you can lose quite a bit. Most oils are good for 500v/mil, I use 300v/mil, and double the distance inside the liquid filled case. But now its time to learn oil vacuum drying.
Carl Pugh
Tue Feb 01 2011, 01:15PM
Carl Pugh Registered Member #1064 Joined: Tue Oct 16 2007, 05:04PM
Oils are fun.
Did the following test:
Put transformer oil in two metal containers.
Put piece of Acrylic plastic in one metal container under the oil.
Applied vacuum.
After a while the oil in the container without the plastic became very calm.
The Acrylic plastic in the container never quit giving off gas. (Acrylic dissolves under a good vacuum?)
One thing that you might be careful of is that
Oil that has all the dissolved air removed has a high breakdown voltage.
Oil that does not have any of the air removed has a high breakdown voltage.
Oil that has some of the air removed has a much lower breakdown voltage.
Tue Feb 01 2011, 03:13PM
Carl Pugh wrote ...
Oils are fun.
Applied vacuum.
whoa! wierd!?
Carl Pugh wrote ...
Really!? i have notbeen told this, strictly speaking its the water vapor i want out not nesscarily the air.
Antonio
Tue Feb 01 2011, 04:05PM
You will need professional equipment to make vacuum below a few mm of Hg. Anyway, all liquid insulators are very poor insulators when compared to solid insulators or to plain air. They can be used only on relatively low-impedance applications where a leakage of many uA is not a problem.
Tue Feb 01 2011, 05:22PM
Antonio wrote ...
Really!? chit! I was going to buy a 100 micron spec'ed rotary vane vacuum pump, single or double stage, and leave the pump continuosly pumping for 6-12 hours to hold the vacuum durring the degassing operation.
Ash Small
Tue Feb 01 2011, 05:49PM
100 micron should easily be obtainable with a rotary vane pump. (especially a new one).
I do think though, that a diffusion pump would achieve better results in this application than a mechanical pump alone, but you'd probably need to consider things like the vapour pressure of the oil being dried/de-gassed.
Mattski
Tue Feb 01 2011, 06:49PM
I would think that heating the oil speeds things up, it makes everything more mobile so it takes less time for a given water molecule to reach the surface of the oil, and when it does it is more likely to leave the oil because it has more energy. I don't know about oil specifically, but usually you bake stuff under vacuum to outgas it and prepare for vacuum use.
On a similar note, more surface area on the oil is good, and if you can maybe use a magnetic stirrer that might also speed things up depending on how much oil you're talking about.
GluD
Tue Feb 01 2011, 07:38PM
GluD Registered Member #1221 Joined: Wed Jan 09 2008, 06:17PM
I agree with Mattski about heating the oil to outgas. As far as I know that is indeed what the professionals do to outgas things before vacuum use.
I'm not sure the magnetic stirrer is a good idea though, couldnt that also "blend in" new gas from the enviorment?
