  • Guests: 56
Would a ZVS driver work as a wireless power transmitter?
Inducktion
Tue Feb 01 2011, 01:28AM Print
It seems like it would, if used with high enough frequency right? Has anyone attempted or tried this yet?
Tue Feb 01 2011, 01:00PM
You fail at using the search function. Link2
Or more likely, the forum search function itself fails. smile
Tue Feb 01 2011, 04:38PM
This little DIY project looks just the thing for a rainy afternoon, and even has a handy PCB template:
RF Push-Pull MOSFET Oscillator with high output power
haxor5354
Thu Feb 03 2011, 10:47PM
can a ZVS even operate over 1 MHz?
haxor5354
Fri Feb 04 2011, 12:10AM
ok it is possible :) i just swapped the 0.68 uf cap on my ZVS to a 4 nf ceramic cap and i was able to get 972.85 KHz according to my multimeter. hooked it up to my induction heater coil, and for the reciving end i just used a hard driver armature coil connect it to a small LED and it lit up!!! can't wait till i get a A+ from my physic teacher :D
123
Inducktion
Tue Feb 08 2011, 10:58PM
Hm, interesting, I'll have to try with different cap values and see how well it runs. Thanks :)
