  • Guests: 63
What do Vacuum Motor?
Inducktion
Sat Jan 29 2011, 03:13AM Print
I have a vacuum cleaner motor i recently ripped from our dead sucker of the dirt.
What should i do with it? Looking up vacuum cleaner motor circuits didn't reveal much, so I'm coming here, begging on my knee's (well not really) for ideas with what to do with this big thing. I probably could make a Turbine out of it...
dmg
Sat Jan 29 2011, 03:51AM
Its a motor, you can do alot with it, your really limited by your own imagination.
for turbines, it makes a pretty crappy one.. if it had metal blades then maybe.. but its not too good as that. All of the ones I found had plastic blades.
Only reason I even keep those is if I want to use one for an async rotary spark gap.
