  • Guests: 46
KAPAGEN, the Tariel Kapanadze's generator
joffa
Sat Jan 29 2011, 01:01AM Print
joffa Banned on 1/31/2011 for signing up to discuss pseudoscience.
Registered Member #3654 Joined: Sat Jan 29 2011, 12:54AM
Hi all, just wondering if anyone here is following this new device that has been successfully reproduced.
Any thoughts would be great.
Grant..
Muttyfutty!
Sat Jan 29 2011, 01:15AM
Muttyfutty! Registered Member #2915 Joined: Fri Jun 11 2010, 10:41AM
Is this meant to me some kind of free energy device?
Inducktion
Sat Jan 29 2011, 03:11AM
...Pretty much looks like it.
Ash Small
Sat Jan 29 2011, 04:29AM
While it claims not to be a 'perpetual motion device', I can't find any circuit diagrams or satisfactory explanations of how it works, other than words to the effect that 'Nikola Tesla was working on a device that would harness the capacitative charge stored in the Earth'.
There doesn't appear to be any scientific explanation of how it is supposed to work, and the photos show wires going 'out of shot', alledgedly to 'earthing points of different potential' It also seems to be a pretty large coincidence that it runs at 50Hz (mains frequency in Europe)
While this article probably doesn't breach the rules of 'General Chat', as previously stated, it contains no circuit diagram or satisfactory explanation of how it works, so it should be consigned to the same bin as perpetual motion machines and free energy devices.
EDIT: The patent:
claims it to be a 'free energy device'.
EDIT 2: The above link doesn't work. You'll have to follow the link in the OPs thread to find the patent.
Adam Munich
Sat Jan 29 2011, 04:30AM
1296275332 2893 FT107323 Btesla
[Edit: Image size (CENSORED)]
dmg
Sat Jan 29 2011, 04:43AM
I second that Grenadier.
Bjørn
Sat Jan 29 2011, 05:22AM
The thought is that it is pseudoscience and not appropriate for this forum. The exception would be if someone has a go at it using the finest scientific principles and in the end has something interesting to tell us.
Mattski
Sun Jan 30 2011, 04:58AM
Joffa, the idea seems to be based on environmental power harvesting (a valid technique, like wind power) but in particular what he is proposing is using variations in local ground potential to drive it. Maybe there is some small power available from this technique, but not likely anything anywhere near worthwhile. Then he discusses something about using displacement current to drive the load at high potential with almost no conduction current, under the theory that without conduction current there would be no power lost. Which is a bit silly because displacement current is not generally lossless (dielectric loss) and the load itself will probably be driven by a conduction current anyway, i.e. with wires with current flowing through them.
And of course right now his device operates with an external power input, like so many "free" energy devices. The output power is measured by measuring light output from halogen lamps. Although a bit dodgy I suppose that could provide accurate results if it's very carefully controlled, though the outdoor setting does not give me confidence that the environment is well-controlled.
Right now JL Naudin is claiming 96% efficiency, I won't hold my breath on him breaking 100%...
dmg
Sun Jan 30 2011, 05:36AM
Looks like OP jumped ship on this thread.
Nicko
Mon Jan 31 2011, 09:16AM
What always worries me with this sort of stuff is the use of poor power measurement - non-calibrated equipment that is not true-RMS and which doesn't allow for PF.
I'm not a scientist (any more) but I would have used a calorimeter or similar absolute method of measuring output power and traceable-calibrated agreed input power monitor.
Just bad "science".
